what bulbs are on your tl?
Land of 10,000 lakes
What's important to you? Color, performance? The brightest ones would be Phillips 85122+ rated at 4300k, resist color change. 3200 lumens, the only problem is they seem to be a little yellow for most peoples liking. Otherwise I'm looking into Osram xenonarc cool blue bulbs. Rate at 5000k with close to the same lumens as the 85122+'s so you get the best of both worlds. I'm running philips ax 6 bulbs that are rated at 6000k lumens suck so output is very poor think they put out 12-1800 lumens.
Coolest A-zine Member
Well this guy didn't exactly seem like the person I'd like to start throwing out new bulb types, Kelvin ratings, etc...haha.
Anyways OP, the higher the Kelvin (K) of the bulb the less light output and the color will change significantly. The color isn't set in stone for every K (6,000K, etc) as some will vary, but most are very close to any chart you can pull up on google. For the brightest temp, anything from 4-5K will do the trick...6 being slightly more blue. Hopefully this quick little write up helps ya
Registered Member
ripit
09-26-2015 06:19 PM
