Warning: Redline High-Temp ATF
Old May 6, 2006 | 09:28 PM
SodaLuvr's Avatar
Earlier today, I have been discussing with another TL owner, AcuraDriver2006, about his experience with Redline High-Temperature ATF. Per Comptech's recommendations when he installed his S/C, he did two drain/fills with Redline High-Temperature ATF, spaced 10K apart, yielding about 65% Redline High-Temp ATF/35% Honda ATF-Z1 in his transmission.
As a result, shifts have been harsh since the usage of this fluid.
The reason is because Redline High-Temp ATF is a Dexron-III/Mercon fluid only. Honda Z1 contains a higher level of friction modification in comparison to a Dexron-III/Mercon fluid. Our owner's manuals specifically state that Dexron-III/Mercon fluids can be used for a short distance, but shift quality will suffer.
Redline High-Temp ATF may certainly be used in the TL transmission, but it requries the addition of Lubegard "Black" Highly Friction Modified supplement, which will increase the level of friction modification in the fluid. You can purchase this additive at Napa Auto Parts for $11.49 under the Napa Part # 7652603. The additive is completely safe and is used by transmission rebuilders nationwide for generating a fluid with the correct dynamic friction properties for Honda and other transmissions requiring a more friction modified fluid. You will need to add 1oz of this additive to every quart of Redline High-Temperature ATF you install.
Just FYI.
Mike
Old May 7, 2006 | 01:16 AM
MichaelBenz's Avatar
CTS-V Import Slayer
Uh.....Sounds about like this thread doesnt it? Why not post the answer over in that thread that already exists?
https://acurazine.com/forums/car-parts-sale-361/xenon-bulbs-bmw-330-a-136408/
Old May 7, 2006 | 01:24 AM
SodaLuvr's Avatar
I'll post in that thread...thanks. I don't think I've ever been to the Parts/Performance section.
Old May 7, 2006 | 01:26 AM
CTS-V Import Slayer
It just looked like GREAT info that they needed and can use over there!!
TypeS860
Jan 10, 2026 11:11 AM
vpasla1
Sep 17, 2016 07:24 PM
EvilVirus
Dec 10, 2015 07:38 PM
hashbrown
Sep 29, 2015 12:13 PM
