VTEC Controller
Old Jul 1, 2004 | 11:17 AM
m0nkeymanxx's Avatar
VTEC Controller
I'm not sure what it exactly can someone help? Does anyone have this in their TL?
Old Jul 1, 2004 | 11:36 AM
caball88's Avatar
i am assuming that you are referring to aftermarket vtec controllers. its simply a device that overrides the factory vtec settings. there are 2 intake cams on the 3.2 engine when the rpms hit 4700 it switches to the second cam. the vtec controller will override this and will switch to the second cam at whatever rpm you set.
Old Jul 1, 2004 | 11:39 AM
ensley696's Avatar
ARe there VTEC controllers for the 04 TL yet?
Old Jul 1, 2004 | 11:42 AM
NightRider's Avatar
SOLD
I thought that these were already optimized as the 1st cam is better for low end power and the 2nd for upper? WHat would being able to be with 2nd cam at say 2000 RPM help with?
Old Jul 1, 2004 | 01:12 PM
caball88's Avatar
it wouldn't help but the vtec is optimized for both performance and fuel efficiency. having the vtec activated too early might do more harm than good when set at 2000rpm. but say setting it to turn on at 4200rpm might help with performance but hurt fuel economy. the vtec in the TL is a very basic one because there is only 2 settins on/off. so the 4700rpm vtec point might not be the best point as far as performance is concerned.
Old Jul 1, 2004 | 01:18 PM
no, It only works for DOHC. This doesnt work for the 04 TL. Plus its for the old V-TEC
NightRider's Avatar
SOLD
I've heard from Acura themselves that i-VTEC is better than VTEC, I know one is for DOHC and one is SOHC. Why wouldn't they be able to inegrate i-VTEC into the TL or at least optimize the VTEC in ours to "perform" in this sport sedan?
Old Jul 1, 2004 | 01:24 PM
caball88's Avatar
iVTEC is for engines with DOHC, the TL has a SOHC and thus does not have the extra cam to adjust the exhaust valve. only the intake valve on a SOHC vtec engine is managed. ivtec is able to adjust both the intake and exhaust valves.
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
