VLED DRL Harness
Old Aug 24, 2010 | 11:08 AM
cali2882's Avatar
BluePearl
Exclamation VLED DRL Harness
Could someone post a DIY on this new harness for the 07-08 TL? I know there are pics for installation of the resistor harness, but how about the relay harness? Where did everyone route and mount the relay harness? Thanks in advance.
Old Aug 24, 2010 | 03:33 PM
jdmvette's Avatar
here's how i did my install.
i routed my drivers side to the passenger side and secured it to the passenger side fan mounting points with zip ties.
i then unbolted the drivers fan and routed the wiring between the fan and radiator, without zip ties.
i didn't mount the relay, i just put it in the area in front of the battery behind the headlight. the relay sits in there with all the rest of wiring.
i also didn't mount the drivers side resistor where they showed it in the v-led pics. i couldn't figure out how they had it so i cut off the side of the aluminum mounting plate that had no holes with a hacksaw and used the bolt that is easily accessable.
i also split a piece of vacuum tube and secured it over the cut edge so the sharp aluminum can't chafe or cut any wiring should the wiring come in contact with it.
it's a great mod, love how bright the 5000k LEDs are.
Old Aug 24, 2010 | 03:42 PM
mglax13's Avatar
New shoes on my
I did the same exact thing. I also mounted up the relay infront of the battery against a support member with a self tapping screw.
Go to the original thread, I posted pics...
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
