Velocity Tuner?
Velocity Tuner?
OK, so I was looking around at some stuff today and I came across this:
http://www.velocitytuner.com/detail.html?prodid=10294
anybody ever heard of such a thing? im questioning it as BS
Let me know
Let me know
2006 Acura TL
Let me know
Let me know
94 DC4 RS LSV/Turbo
dude this is like the intake turbonator thing... if you think air is going to begin to swirl because of this you sir.... no comment reply ends now
Registered Member
There are a few simple "tests" that you can use to determine whether or not a product such as this does what the maker/seller claims it does.
One. Does it come stock on the car or engine? Take a look at the product in question. It is quite simple and therefore easy to install as well as inexpensive. If it produced the kind of increases in power and fuel economy along with a reduction in emissions that the maker/seller claims it does, you can bet your bippy that car manufacturers would be snapping this little gem up in a New York minute.
Two. Do we see racing teams making use of this product? Don't you think that if it did what it claims, a host of racing teams would be snatching this puppy up in droves?
Also, anytime you see an ad that states "up to 21 more HP and up to 10% better mileage", if it was responsible for even 1/10th of a percent increase in these areas, the ad would be true because a .001 increase in HP would satisfy the "up to.." statement.
And then there is just plain logic. This product is installed in front of the throttle body I believe. What small amount of "swirling" that may possibly be created is going to disappear by the time the air flow makes its way through the intake manifold and plenum to the intake valves. As a matter of fact, engineers want a smooth, uninterrupted flow of air through the intake passages in order to reduce turbulence and negative pressure waves.
Interesting logic- if you think auto makers would add something to make better mileage.
They are all in agreement with big oil and the govt and do as little as possible for the buying public. Its all on a very organized schedule of release- 10 years from now.
Makers have engines that get great mileage sitting on the shelf.
Why should they sell you that when you will buy what they give now?
Air actually does rotate-swirl as it moves, perhaps you have watched the weather news on TV, low pressure rotates counter clockwise.
The VTEC part of our car changes the lift-timing and duration of the 2nd intake valve on each cylinder. It slightly delays the opening of 2nd intake valve- creating a swirling tornado effect inside the cylinder- mixing the fuel and air better.
The Tornado sold on tv and parts stores only works on non vtec or vortec engines.
But we already have a built in setup.
Want better mileage and handlng?- check you tire pressure monthly.
I can get you the same gains, send me $25, Ill have someone come over there and smack you upside your head for thinking this would work
But in reality, it doesn't work may also cause additional problems
Registered Member
Now as for;
"They are all in agreement with big oil and the govt and do as little as possible for the buying public. Its all on a very organized schedule of release- 10 years from now.
Makers have engines that get great mileage sitting on the shelf."
I have heard that little argument for close to 50 years and it's nonsense. I'll tell you why. Let's take it back to, say, 1963. GM had well over 60% of the new car market in the U.S. So let's say Ford happened upon a technology (carburetors) that could increase fuel economy by 40%. Since Ford had a significantly smaller share of the market than did GM, do you really believe for one moment that they would say, "Wow, our R&D department has come up with a carburetor that will increase the average MPG of our full sized sedans with the 390 CID engine from 15 MPG to 21 MPG., but we'd better not install this into our cars because we wouldn't want to upset Standard Oil."
No way. Ford would push that puppy out in their cars as fast as they could to try to increase market share and take some business away from GM and Chrysler. That's called capitalism and the free market system.
Registered Member
Now one thing I would like to know. What is your source of information for your following two statements?
"Its all on a very organized schedule of release- 10 years from now.
Thanks.
Up to 16% power increase...thats like 40hp I'm sold!!
Lolz did you read that in the national inquirer?
cycdaniel
12-17-2019 10:58 AM
09-14-2015 10:48 AM
