USR SwitchBack LED Side Marker Light Official Release!!
yea, mine fit with no issues. all four are on there good, will require some force to get them off, will definitely cause paint damage if someone tries to steal them.
some of our "holes" must be tighter than others...
I had the same issue on the rear for BOTH of my sets of lights.
Putting something like a napkin or something rubber BEHIND the clip is probably an excellent idea so it stays firmly in place once you pop it in.
just wanted to give everyone a heads up to check that their sidemarkers are still snug and tight.
mine were nice and tight when i first installed them, i was washing the car today and noticed both my front and rear on the passenger side were loose.
Went through the car wash yesterday and it pulled the light completely out and the tab that doesn't snap into place is hanging on by a thread. I tried the razor method Rockstar143 suggested but it didn't seem to work for me. I thinking for the mean time I am going to get some 3m double sided tape and replace some of the gasket on the side with the broken tab.
Has anyone contacted USR? I've been slammed and haven't had the time yet.
My fronts clicked into place and were a pita to take out...the rear 2 were my only problem. If you create a groove with the razor, it should allow the clip to pop out when in place and hold it. At least on mine it did.
^did you dremel a notch on the rear ones? thats a must.
the fronts should just pop in tho. not sure why you're having issues. try and see which part is not popping in right and dremel a little tab on the sidemarker so it has something to catch onto.
takin care of Business in
^^^ Aaron, i think the issue they are having is the sidemarkers are not "popping" in....they are kinda loose....
i think the electrical fitment (dremeling the electrical connector) is a given with the Type S connector....
the "fitment issue" is really something that is very simple to address. And for the price he's charging for a switchback sidemarker, I would NOT let it stint your decision to pull the trigger. If you get stuck, PM me and I'll walk you through what I did to get it to pop into place.
^^^ you can make them blink....
buy these:
http://www.uniquestyleracing.com/20actlclorsm.html
and follow these instructions:
https://acurazine.com/forums/3g-tl-2004-2008-93/g-043-blinking-sidemarker-diy-guide-suitable-3g-garage-703668/
buy these:
^my repeated requests went unnoticed so i just have the switchback USR's as is right out of the box.
white while running, when turn signal is applied the fronts blink amber and rears blink red.
i will, one day, go back and figure out a way to make the rears RED and blink RED.
And using this logic couldn't you just tap a stock side marker to the turn signal wire?
Hmmmmmm so I been wanting to buy these for awhile but like a few people I want the rear to be red-red not white-red and I want the rears to blink also. :/ has anyone come up with a solution to this? got my switchbacks installed two days ago now I need my matching side markers to be complete with the switchbacks for all 6. Pulling the trigger once someone finds out how to make the rear stay red and blink red.
John Ebelp was the one that suggested that to me, tap your regular constant parking light power wire with the signal trip wire...it SHOULD make it red ON and then blink red too. The red led's are in there...obviously.
