Useless question
Old Jun 14, 2004 | 01:00 PM
Saintor's Avatar
Useless question
The TL automatic transmission will always shift to second gear, want it or not. You can't keep it in 1st. :'( Is there any (relatively easy) way to change this?
Of course, I am not sure that I would do it under warranty.
Old Jun 14, 2004 | 01:01 PM
prophet_RENAMED's Avatar
'L' will do that.
Old Jun 14, 2004 | 01:10 PM
Ron A's Avatar
Administrator
Originally Posted by prophet
'L' will do that.
L will also shift to 2nd by itself. There is no way to hold either L or SS in 1st.
Old Jun 14, 2004 | 02:09 PM
rets's Avatar
Moderator Alumnus
'L' will do that.
L only helps you stay in 1st gear longer... but forever...
Old Jun 14, 2004 | 02:17 PM
Michaelvg1's Avatar
I found that putting it in low will keep it in first. Once I reach a high RPM I push it up and pull into SS. Now it's in 2nd. You have to do it quickly so that it does not go into 3rd or 4th.
This works pretty well.
Old Jun 14, 2004 | 02:21 PM
Ron A's Avatar
Administrator
From the Owner's Manual, page 183:
"Accelerating in first gear, the transmission upshifts to second gear at about 37 mph. You must move the shift lever to D to upshift to third gear."
Old Jun 14, 2004 | 02:35 PM
NightRider's Avatar
SOLD
'L' will do that.
Depending on how "ready" the engine is, it will upshift accordingly. I have found that if you keep it in L or D, it USUALLY will upshift right around 6800 whereas in SS1 or L sometimes it tends to shift around 6300...if you are "Racing" then the best thing to do is probably either keep it in D or L (keep foot on gas always) and when IT (not you) upshifts to second at redline, go SS2 and you should be able to get 75 in SS2
Old Jun 14, 2004 | 02:49 PM
rets's Avatar
Moderator Alumnus
I'm not sure the right RPM... but TOV site ever had the video displaying the shift-point of RPM on SS mode and D mode.
Old Jun 14, 2004 | 08:04 PM
Xpditor's Avatar
Can you give specific directions on how to find that? (You usually do :-) )
mlody
Dec 4, 2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
