Under Dash Panel
Old Feb 17, 2008 | 03:08 PM
Bama Acura's Avatar
5th Gear
Under Dash Panel
2006 TL. There is a panel just above all the pedals I want to take down to get access up inside to run wires for radar detector. There appears to be one rubber fastener at center by firewall, I have no idea how to undo it. Something like it is near the forward part of dash, near right knee.
How do you pull this panel?
Old Feb 17, 2008 | 03:13 PM
MWalsh9152's Avatar
all work and no play
grab the pannel at the back and pull it down, there are two clips holding it up there, then slide it back the rubber piece just sits in a mount and will slide right out
Old Feb 17, 2008 | 05:47 PM
Bama Acura's Avatar
5th Gear
Under Dash Pqnel
Thank you. Once I understood how it came out, it was easy! I got the upper left side out too, and mounted the detector control (a Beltronics) in the hole where I took out the blind cap next to the mirror controls. Looks good now.
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
2Quik
Sep 23, 2015 01:03 PM
eastcoastguy
Sep 23, 2015 06:29 AM
