UA7 on e85
Old Sep 19, 2016 | 01:08 PM
Nazar-ua7's Avatar
4th Gear
UA7 on e85
I have a 2007 ua7 and I was wondering if any one also has a 3rd gen type s that runs e85, and knows what needs to be done, if it's worth it, what are the down falls, and how much it might cost.
Old Sep 19, 2016 | 01:09 PM
^might as well buy a car that sips E85 from the factory.....
Old Sep 19, 2016 | 09:15 PM
csmeance's Avatar
Since it doesn't seem like you've done any research let's give you a crash course:
E85 has better cooling properties and "higher" octane than E10. It improves "efficiency" by around 1% but requires nearly double the volume of fuel delivery, essentially your MPG will drop by 1/2 and your fuel pump is going to be working harder along with injectors. E85 is much more corrosive and can damage fuel system components and possibly your engine if it was not designed with E85 in mind.
Factory fuel pump, rails and injectors can't deliver enough cc's of fuel if you use E85 on the TL. Even the BMW 335 (E9X) requires 50:50 E10 Premium to E85 with a custom tune, and that's maxing out the fuel injectors.
With no turbo or S/C, you honestly are going to have a lot of trouble and no gain in any sort of way.
If you have turbo or S/C, you can easily add 100WHP tuning with E85, just have to make sure you edit the tables on your tune to deliver a lot more fuel.
Old Sep 19, 2016 | 11:15 PM
Nazar-ua7's Avatar
4th Gear
well that just about answered all my questions, thanks, that's much appreciated
Old Sep 20, 2016 | 12:03 AM
csmeance's Avatar
no problem! Hope you got the joke about the crash course!
Pride96
34
Sep 19, 2016 10:58 AM
oneeb97
New Member Introductions
Jul 11, 2016 09:42 AM
cib16waker
Jun 23, 2016 07:22 PM
Rob_TL
20
May 25, 2016 01:43 AM
gavriil
Oct 4, 2002 06:35 PM
