TypeS tails : anything in particular to watch for?
2021 RDX A SPEC
I'm picking up a set of used OEM typeS tails tomorrow.
Is there anything I should look out for? broken/snapped tabs? any sort
of bracket needed? condensation dmg?
Also, do the OEM have honda stamped on them somewhere to help distinguish
them from the DEPO ones?
Thanks all.. as for installation, I will do it the 'easy' way and that is
remove the 2 screws from each inner wheel well, remove the 2 10mm
bolts in trunk and just pull off the bumper enough to get access to the
brackets holding down the lights.
RPF1+RS3 FTW
OEM ones do have Honda stamped on them I forget where exactly. Obviously look out for broken tabs or corners. Here is what happened to the first set of tails I picked up during shipping.
You don't wany anything like that. Should be fairly obvious just look them over for damage. Good luck, and post pics when you get them installed.
mrkingstonvi
02-22-2016 01:53 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
