Type-S owners!! Are your rear calipers black?
Old Mar 17, 2009 | 08:40 PM
TLAdvanced's Avatar
The Kinetics of Bleu
I was looking in another thread and debating with another member about Type-S rear calipers. They said that the rear calipers are supposed to be black. Mine are unpainted, were they supposed to be painted black from the factory?
Old Mar 17, 2009 | 08:43 PM
good question. i gota check
Old Mar 17, 2009 | 08:47 PM
CubanLynx84's Avatar
under renovations....
Is yours an 08 or 07 maybe if it an 07 maybe they didn't come painted from factory. Just guessing on that. But mine are painted for sure and it's an 08
Old Mar 17, 2009 | 08:58 PM
TLAdvanced's Avatar
Good point, mine is an 07...
Old Mar 17, 2009 | 10:10 PM
myphuocinTL's Avatar
>_< never noticed it, mine aren't painted either..... (07 TLS)
Old Mar 17, 2009 | 10:16 PM
Yvuru's Avatar
Mine are unpainted. The drum is rusty too.... I think its called a drum.
Old Mar 17, 2009 | 10:54 PM
Bearcat94's Avatar
AZ Community Team
They were a grey-ish color. But they are black now.
Old Mar 17, 2009 | 11:19 PM
H23Accord's Avatar
iWhine
I think you are talking about the "hub" of the rotor. Mine is rusty as well. In somewhat relation to the original post, I have seen people paint their rears black, as well as have the rear hub painted black to help keep it from rusting. Looks a lot better too. There are also aftermarket rotors made with the hub already black which helps prevent the rust.
Old Mar 17, 2009 | 11:58 PM
Integra's Avatar
2007 Acura TL-S
i have an 07, unpainted
Old Mar 18, 2009 | 01:16 AM
08pearlwhite's Avatar
I have an 08 Type S and mine calipers are painted black
Old Mar 18, 2009 | 01:42 AM
Integra's Avatar
2007 Acura TL-S
from all the results we got, im guessing 07 unpainted, 08 painted.
Old Mar 18, 2009 | 01:45 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Unpainted (06 obviously!)
OP your car on the sides look like a BMW, only thing that makes it look more like an Acura is the wheels.
Old Mar 18, 2009 | 06:37 AM
LoveMyTL-S's Avatar
Well, I left the office to look at my rear calipers (I'm parked in the front row) and found that they are not painted. I have an 08 TL-S. They are a dark in color but it's bare metal. Are you guys that say they are painted sure? Perhaps we should start a poll
Old Mar 18, 2009 | 06:59 AM
BlacuraTLTYPES27's Avatar
This perplexed me last weekend when I was washing my car. I had always thought they were painted, but realized that they were just bare metal...2008 TL-S
Old Mar 18, 2009 | 08:21 AM
vinnier6's Avatar
07,08 rears are all the same, type s or not....
Old Mar 18, 2009 | 08:31 AM
Tripnbeats's Avatar
maybe the paint adds to the stopping power??
Old Mar 18, 2009 | 08:58 AM
John06's Avatar
Guys I read a long time ago that the rear calipers on a 2008 TLS is a brembo 1 piston calipers painted black from factory to match the front.
This was from the the Acura website, describing the 2008 Tl type S
Old Mar 18, 2009 | 09:47 AM
Bearcat94's Avatar
AZ Community Team
WOW! I was gonna call , but you are EXACTLY right:
Both manual and automatic transmission TL Type-S models include a special Brembo brake package that includes 12.2-inch (310 mm) diameter ventilated front rotors clamped by 4-piston brake calipers. On the rear, the Type-S makes use of 11.1-inch (282 mm) diameter solid rotors mated with Brembo single-piston brake calipers. The calipers have an aggressive pad material to offer improved brake feel and to reduce fade in hard, repeated brake applications. The Brembo calipers are also 30-percent lighter than the standard calipers, reducing unsprung weight by 4.3 pounds per wheel, which in turn improves suspension response for better ride and handling. The calipers feature an attractive black painted finish with the Acura name. Rear brake rotors are the same 11.1-inch solid discs as used on the TL, but the calipers are given a black finish to match the look of the front brake calipers.
http://www.hondanews.com/categories/735/releases/4213
Sorry I doubted you.
This is for the '07 TL-S (does not say anything about Brembo rear calipers):
.... Rear brakes are the same 282 mm solid discs as the TL, but the calipers are given a black finish to match the front brake calipers. ....
http://www.hondanews.com/categories/735/releases/3745
Old Mar 18, 2009 | 09:58 AM
LoveMyTL-S's Avatar
My rear calipers are dark in color but don't appear to be painted black. I have an 08 TL-S.
Old Mar 18, 2009 | 10:14 AM
georgegiorgio's Avatar
G Force
Well, I went to Acura OEM, and pull the calipers for both TL-S 07 and 08
The Part # are exactly the same, only difference are the diagram showing the parts in drawings.
2007
http://www.acuraoemparts.com/delray/...All&vinsrch=no
2008
So, which statement is true?
Old Mar 18, 2009 | 10:32 AM
Bearcat94's Avatar
AZ Community Team
2007
2008
I gotta go with the Honda News articles. That's the word right form the horses mouth. I suspect both 2007 & 2008 are the same caliper manufacturer, they just didn't mention it in the 2007 release.
I said mine looked "grey-ish", not like the bare metal I had on the '02, but like faded, worn out paint. I repainted them last week.
Old Mar 18, 2009 | 10:39 AM
jptl04's Avatar
Bone stock tl-s
mine were dark in color like they were painted very lightly. not bare metal. just take some dupli-color black caliper paint and paint them yourself like i did then if you're not satisfied spray on a few coats of hi-temp clear coat on them. your set
Old Mar 18, 2009 | 11:08 AM
jweb12's Avatar
Mine are black on my 07. It's not a nice clean painted finish like the front calipers, but they're black.
Old Mar 18, 2009 | 11:14 AM
paliknight's Avatar
mine are a grayish color
Old Mar 18, 2009 | 11:30 AM
TeknoKing's Avatar
08 TL-S.. black rough finish.... definitely not clear coat painted like the front.
Old Mar 18, 2009 | 11:59 AM
Tripnbeats's Avatar
see black=stopping power =)
Old Mar 18, 2009 | 01:08 PM
chuanger's Avatar
One or Two?
My 08 TL-S has a rough flat black paint with no clear coat. Looks like a really dull black compared to the front brembos.
Old Mar 18, 2009 | 01:33 PM
Sal's Type S's Avatar
Mines on my 08 are Black as well.
Old Mar 18, 2009 | 01:53 PM
dj5's Avatar
dj5
So are mine, but I plan on painting them black along with the rotors in the next couple of weeks.
Old Mar 18, 2009 | 01:58 PM
ZhenyaF's Avatar
Off roading in his
My 07 TL-S dont seem to be painted.
Old Mar 18, 2009 | 02:05 PM
John06's Avatar
Smile
No Prob Bearcat... lol
Old Mar 18, 2009 | 03:38 PM
PhilB81's Avatar
same here
Old Mar 18, 2009 | 04:01 PM
BG74's Avatar
I have an '07 and my rear calipers are black
Old Mar 21, 2009 | 02:22 PM
TLAdvanced's Avatar
So, what people are saying. Ahem, Bearcat! Is that all TL-S should have black painted rear calipers. The 08's are 1 piston Brembos? So, is it feasible to ask the dealer to install the black calipers?
Old Mar 21, 2009 | 02:31 PM
Steven Bell's Avatar
Mine aren't, but they should be!
2009 Kansas City Acura Meet
https://acurazine.com/forums/midwest-312/kansas-city-2009-spring-all-acura-meet-may-17th-12pm-%40-jay-wolfe-acura-714994/
Old Mar 21, 2009 | 08:41 PM
Japs08's Avatar
I have 08 Type-S but the rear is not painted unlike the front.
Old Mar 21, 2009 | 08:46 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
^^^ are you sure?
I looked at my friends 08 and he thought they were not painted but then I was like your calipers are painted man and he looked at mine and then looked at his and was like oh yeah they are. They are painted black but its a very rough black not like the nice glossy finish on the fronts.
Old Mar 21, 2009 | 09:05 PM
vinnier6's Avatar
people, they are all the same, some people just descripe what they are seeing differently....someone who thinks their rears arnt painted take a pic, and someone who thinks they are painted take a pic, and i be they are the same.....they are just a rough painted...not like the front brembos which are high gloss clear coated...
Old Mar 21, 2009 | 09:11 PM
jweb12's Avatar
^ Exactly.
Old Mar 21, 2009 | 09:47 PM
TLAdvanced's Avatar
Ok, then if that is the case I would like to see a photo of a base TL rear caliper and I will post a pic of my Type-S rear caliper. I bet they are the same. There is NO WAY mine is painted black, whether flat or clear it is no shade of black.
