Turn Signal LED's?
#41
AZ Community Team
Received 7,770 Likes
FWIW:
Sylvania Bulb Replacement Guide for the 2007 TL/TL-S says:
7440 for the Rear Turn Signal
1157 for the Front Turn Signal
http://www.sylvania.com/ConsumerProd...placementGuide
(OTOH, that's also the guide that says the 2007 Fogs are 9006, when if fact they are H8. Caveat Emptor.)
#42
OMGWTF4THGENTL
Have you guys tried the blinkers without the resistor... ?
I like the flashing 2X as fast.
It's more attention getting that way.... being a motorcyclist, you're mentaility always seems to focus on safety and gaining the attention of "other drivers", and the rapid flashing seesm to do that.
The faster flashing seems to say:
"Hey you, I'm turning left, watch out, here I come... Here I am, Hey mo, turning left... who hoo", at least that's how I feel out on the road when I use them now.
I'm fine with it flashing faster rather than hacking those nasty heatsinks into my turn signal wiring. Now if we ever figure out the "relay mod" to fix this, I may consider that.
#44
King of NYC
#45
A J35A8 EG civic is in
#46
OMGWTF4THGENTL
Originally Posted by rockyfeller
My brain may be working a lil slow today but I almost believed you. Please tell me you're joking right?
and I just can't seem to get passed those heatsinks... what a caveman way to compensate.
I say, let it blink fast.
#47
AZ Community Team
Now you sound like that guy was about the TPMS Banding Strap Solution - Such a CRUUUUDE Solution!! lol
#48
OMGWTF4THGENTL
It's not so much the crudeness, but the heat concern. These things get hot... Not only that, they consume mucho power... more than the stock bulbs. That's what I don't like.
#49
King of NYC
No arguement about the energy waste.....200watts with the hazzards on!! My alternator will fry once I wire my 1000W Rockford Fosgate amp!! I have to do something about it because I doubt my 1fd capacitor will suffice!
I only use the signals when necessary and don't leave them on longer than 30 sec. I mounted the resistor onto metal well away from anything else to prevent catastrophe. The resistor is exposed to plenty of air circulation and uses the metal as well as the heatsink to dissipate heat. Wish there was another way but until someone invents one I settle for this.
#50
OMGWTF4THGENTL
I'll just let my blinker blink fast.
#53
it's me, Alan Rickman.
also - autolumination has:
6 OHM 50 Watt LED Load Equalizer
Adds a 25 watt load
Says 2x required per side
but...
3 OHM 50 Watt LED Load Equalizer
Adds about 50 watts of load, 1x per side
So you could get the 3 ohm / 50 watt setup and only have to install 2 in the rear ?
Edit - found this from autolumination - it says one 3 ohm / 50 watt resistor per side if you're installing front and rear LEDs, if you're doing only the front or only the rear you need one for each LED unit installed
Adds a 25 watt load
but...
![](http://superlumination.com/images/leds/installation.jpg)
#55
OMGWTF4THGENTL
Good find Timmah, but you're misreading the broken english. You need to install one at each corner. You need 2 6 ohmers front or rear if your doing front or rear only, or 4 3 ohmers if you're doing led all around.
Adds a 25 watt load
but...
Adds a 25 watt load
but...
#56
I have a friend who is a electrical engineer...I need to talk with him and see if there is a better way to do this. I hate the idea of something electrical getting hot that I "need" to make the car act normal.
#57
iWhine S/C 6MT TL
^ thats the way you do it..... if there was another way someone would have done it already
#59
King of NYC
Yeah the wording is confusing about load resistors. I put 1 at each corner but I am pretty sure I could have gotten away with splicing them into both left and right sides front or rear and doing away with 2 of my 4 resistors. I'll look into it in the spring. Waste of energy!
#60
If you have LEDs in all 4 corners, you still need 4 resistors (depending on what ohm and all that) but you dont have to put them all in the 4 corners, you can put 4 in the back or 4 in the front (2 per side)
#61
#62
Originally Posted by BrianC636
If that's the case, why couldn't a person figure out how much power is consumed by the standard bulbs, minus the power used by the LEDs, then build a resistor to match the power originally consumed. This would eliminate 2 resistors that you needed to wire in.
All I know is that I have LED signals in all 4 corners and I put in 4 resistors in the back (2 for each signal) and they work perfectly fine.
#63
King of NYC
uhhh sunny, I'm not getting what you are saying...you say you put 2 resistors per bulb? (2 per corner? 8 total for the car.) That's not necessary. You only need the resistors wired to the signal leads to give you a normal flasher rate. (1 per corner or 4 for the entire car.)
If you had a car like say a BMW which has the additional problem of giving you "bulb burned out" warnings on your OBC then you'd have to wire in an additional resistor to the parking light as well. Then you would need 2 resistors per bulb (8 total on the car)
I am trying to say that I think you may only need 2 resistors for the whole car. 2 lights could actually share a resistor. Someone please enlighten me about how the math adds up theoretically as I'm not good with that stuff. I'm sure someone will know if it is possible or not. I don't care what autolumination says. They just wanna sell more resistors. Brian is right. I think it would be easy enough to build (and cost less than $15x4 to make) 1 resistor for the whole car.
#64
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
