tune up!!!!!
Old Jun 21, 2010 | 10:47 AM
sabioj's Avatar
[IMG]http://tl.acurazine.
Question tune up!!!!!
what is a tune up consisted of on a 04 tl?... trying to get it done today??? i have 90,000 miles on it so far!
Old Jun 21, 2010 | 11:10 AM
01tl4tl's Avatar
seafoam,
NGK iridium spark plugs
engine air filter
cabin air filter
ck tire pressures
wash car
done
Old Jun 21, 2010 | 11:20 AM
sabioj's Avatar
thanks man...i appreciate that
Old Jun 21, 2010 | 11:52 AM
LoveMyTL-S's Avatar
Make sure to do the seafoam before changing the plugs.
Old Jun 21, 2010 | 12:03 PM
sabioj's Avatar
where can i get seafoam?... is it easy to do?
Old Jun 21, 2010 | 12:04 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
If I were you, I'd wait till 105k service.
Spark Plugs
Cabin Air Filter
Drain & Fill brake fluid
3x3 Transmission fluid
Inspect Power Steering fluid
Check Coolant (A/C) Levels
Inspect Antifreeze Levels
Replace/Inspect Belt tensioners
Replace Timing Belt
Replace Water Pump
Oil Change
Tire Rotation (Balance, Alignment if needed)
Seafoam
Detail Car
After that, you have a brand new car.
Old Jun 21, 2010 | 12:28 PM
TiggaMan909's Avatar
In Search Of Sunrise....
so the dealer provided 105K service includes seafoam?
Old Jun 21, 2010 | 12:38 PM
This is assuming you're doing most of the maintenance yourself besides replacing the belt tensioners, water pump, and timing belt.
Old Jun 21, 2010 | 12:51 PM
LoveMyTL-S's Avatar
You can get Seafoam at most auto parts stores as well as Wal-Mart. It's very easy and plenty of instructions in here, just search.
Old Jun 21, 2010 | 05:36 PM
KiWiLiT43's Avatar
Sorry to steal the thread but what are the tune up intervals? I am approaching 60K... Thanks!
Old Jun 21, 2010 | 05:52 PM
poormans_tl69's Avatar
CARBON FIBER WDP TL
the dealer will rape you.. i have connections with the service manager and we always do work for them since i paint cars at a body shop...talk to your service manager at your local dealer
Old Jun 21, 2010 | 06:35 PM
nttstt444's Avatar
im not positive but i believe 30k, i know for sure 105k and theres most likely one between 30k and 105k. if it helps any, my 08tl just hit 55k (yea i drive a lot) and i just got new tires, coolant and atf replaced, and an oil change...
Old Jun 21, 2010 | 06:43 PM
Turbonut's Avatar
Providing the plugs are the OE, they will be good until the 105K mile mark
Old Jun 22, 2010 | 02:10 AM
01tl4tl's Avatar
a point we disagree on- I feel anything over 60 merits new spark plugs assuming most of us fit in the severe service use limits
I dont care what the book or advertising says- everyone who does it gets 1mpg increase
you can seafoam on new plugs- wont hurt then, but its better to do a few days before if you can
Old Jun 22, 2010 | 05:51 AM
Turbonut's Avatar
You can disagree all you want, but changing plugs will not yeild any performance or mileage increase. Naturally this is assuming there isn't a dead plug/coil, but the vehicle is operating as normal. Don't believe me, take a look over on the NGK sight and you'll find back up evidence that with today's electronic ignition, changing the plugs will yeild no increase in performance or mpg. Hate to admit this, but the daughter's Maxima had 135,000 on the OE plugs and no improvement after changing plugs.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
