tune up!!!!!
seafoam,
NGK iridium spark plugs
engine air filter
cabin air filter
ck tire pressures
wash car
done
engine air filter
cabin air filter
ck tire pressures
wash car
done
Chapter Leader (San Antonio)
If I were you, I'd wait till 105k service.
Spark Plugs
Cabin Air Filter
Drain & Fill brake fluid
3x3 Transmission fluid
Inspect Power Steering fluid
Check Coolant (A/C) Levels
Inspect Antifreeze Levels
Replace/Inspect Belt tensioners
Replace Timing Belt
Replace Water Pump
Oil Change
Tire Rotation (Balance, Alignment if needed)
Seafoam
Detail Car
After that, you have a brand new car.
Spark Plugs
Cabin Air Filter
Replace Timing Belt
Replace Water Pump
Oil Change
Seafoam
Detail Car
CARBON FIBER WDP TL
the dealer will rape you.. i have connections with the service manager and we always do work for them since i paint cars at a body shop...talk to your service manager at your local dealer
a point we disagree on- I feel anything over 60 merits new spark plugs assuming most of us fit in the severe service use limits
I dont care what the book or advertising says- everyone who does it gets 1mpg increase
you can seafoam on new plugs- wont hurt then, but its better to do a few days before if you can
MrHeeltoe
20
02-23-2023 01:54 PM
ExcelerateRep
10-14-2015 08:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
