TSB's are they fixed for nothing??
Old Jul 27, 2005 | 06:45 PM
muadib's Avatar
I'm having trouble with my brakes vibrating when I use them. My dealer said the problem isn't covered under waranty, and that I should wait until I need new pads to fix the problem. He said this over the phone, and it didn't sit well with me, so I look here to see if anyone else if having the same issue. Sure enough, I find a thead that leads me to this link:
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
Sure as crap, there's a TSB for this issue. Are TSB's fixed for free?? Is there any sites that we can get the full details of the TSB's?
Old Jul 27, 2005 | 07:05 PM
Donte99TL's Avatar
Does anyone read this
Your dealer is stupid. It's covered under the warranty.
Old Jul 27, 2005 | 07:06 PM
Adobeman's Avatar
The DVD-A Script Guy
TSBs don't apply to all cars all the time. Many times there is a serial number range. If your car is in that range and you can demonstrate the problem to the dealer then you are in a better position to have it done.
Also, brake wear is often covered under a different "wearable items" warranty. (Often, for example they are 12mo/12Kmi) I'd have to check the docs that came with the car to see what the Acura term for that is and what the specifics are. Check your manuals and warranty booklets and you should find something.
If the age and mileage of your car are beyond that point then you will have to rely on good will. If you are still within the range AND the TSB really applies to your car then press the dealer and involve the regional Acura reps is it comes to that.
But first try and remember if you really smoked the brakes early on an just warped a rotor. If you did then just keep that to yourself....
Old Jul 27, 2005 | 07:07 PM
empathy's Avatar
go get him saying that it's not covered under warranty in writing. then, go drive into a tree and then sue the dealership. blame it on brake failure that the dealer wasnt willing to fix it.
Old Jul 27, 2005 | 07:28 PM
Your car will never be the same, you may be paralyzed, but you'll get back at the dealer? LOL
Old Jul 27, 2005 | 08:28 PM
empathy's Avatar
with the money you will get from the lawsuit, you dont have to worry about driving a TL again :P
Old Jul 27, 2005 | 09:34 PM
brich2929's Avatar
Hey, maybe then you can move up to the RL!!!!!!!!!!!!!!
Old Jul 27, 2005 | 11:14 PM
BUD001's Avatar
just show them the bulletin..... if not, go to another dealer and lodge a complaint against the dealer via Acura North America corp. office.
Old Jul 28, 2005 | 05:38 AM
muadib's Avatar
I hear you, but I shouldn't have to show them the bulletin, they should already have it! I'll see what happens next week, but I think I see a call to Acura North America in my future.
Old Jul 28, 2005 | 11:01 AM
Road Rage's Avatar
Not a Blowhole
adobeman is right - almost always, a decent Acura dealer will cover this under the 12k customer sat warranty period.
Of course, it depends on what caused the problem.
1) Most rotor warpage on new cars is from people riding the pedal, or from over tightened or inconsistently tightened lug nuts yanking on the rotor hat. Modern rotors strike a balance between fuel economy, and long-life. Acura uses high quality steel, whereas cheapies like Ford make tissue-thin rotors and hope their owners do not notice (I had bad experiences with my old SHO).
2) Acura recommends that the rotor turning be done on the car, and so do I - as long as the wheel bearings are not defective (or worn on an older car), this will almost always result in a good result.
3) Since quality aftermarket rotors are available aftermarket, I always replace (and resirface myself) them when I do even a pad change or swap on any of my "good cars".
Old Jul 28, 2005 | 12:00 PM
SamiaM68's Avatar
TSB's are different from recall's in that the problem listed in the TSB doesn't affect enough vehicles to warrant a recall. If your vehicle is still under the factory warranty than a TSB affecting your VIN range is covered.
Using your example, I had the rotors resufraced twice on my 04' TSX under warranty before I traded up to the TL...
Hope this helps!
Old Jul 28, 2005 | 12:40 PM
empathy's Avatar
from my experience, warped rotors happen when there wasnt a good install of the brake system or the brakes werent given time to cool down and the car was parked with the rotors HOT. this happens to a lot of road raced cars. they park with their e-brake up and their rear rotors tend to warp cause of this issue.
Old Jul 29, 2005 | 08:11 AM
Oswald Vater's Avatar
I'm not sure what the policy is on this and whether the manufacturer or dealer determines how its handled but we used to have an early-build 96 Caravan that had numerous problems corrected by TSB's. I took it back to the dealer with a list printed from NHTSA's site and said I wanted them fixed as warranty issues and they did them all for free. It can't hurt to try the same thing with your dealer.
Old Jul 30, 2005 | 10:10 AM
muadib's Avatar
Very good idea, thanks!!!
Old Jul 30, 2005 | 10:21 AM
Neorick's Avatar
Your Dealer is a cheap bastard. I have the same issue and the dealer took care of it. See Attached Link:
https://acurazine.com/forums/showthr...=117675&page=1
Old Aug 1, 2005 | 12:10 PM
muadib's Avatar
How many mile did you have when you went in for service?
Mike734
Dec 10, 2021 01:25 PM
thegipper
Sep 28, 2015 01:01 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
flybyglass
Sep 24, 2015 01:12 PM
JOE COOL
2G RDX Problems & Fixes
Sep 24, 2015 07:15 AM
