TSB & VIN
Old Mar 31, 2004 | 01:51 PM
Thomwarn's Avatar
Exclamation TSB & VIN
Dumb question.... What's all the chatter re: vin numbers, is it the last four digits that signify when it was built, and the higher the number means later production? If so, from what VIN number did some of the early problems get ironed out?? Thanks for the help!
Old Mar 31, 2004 | 01:54 PM
caball88's Avatar
its the last 5 digits. the bigger the number the newer the car. i think all cars under 18XXX might have the memory seat problem. As for the new tires all cars around 33XXX have the "new" el42 tires. but the problems are all scattered. not every single car will have it.
Old Mar 31, 2004 | 02:00 PM
Ron A's Avatar
Administrator
It is the last six digits, so 00XXXX would be the full serial number part, and they go insequence, but Canada starts with 8, so higher number means newer production. There is a sticker in the driver's door jamb with a month and year production date, if you want more exact date dealer can get from computer (you can't).
Vehicles through 018476 had the memory seat problem, then it was fixed.
If you get anything produced with VIN over 02000, which these days should all be well over that, most all problems have been corrected. And the tire thing as caball88 said above.
There are lots of individual (one or two owner) problems that crop up here and there, but mainly the newer ones, as reported in this forum from what I can remember, as doing well.
If I missed any major current problems, bring it up.
Old Mar 31, 2004 | 02:12 PM
rets's Avatar
Moderator Alumnus
EL42 vibration issue: up to 031030
:argue:
Thanks Lore's info.
rets's Avatar
Moderator Alumnus
Lightbulb 03-023: TQI and New Model Information.
rets's Avatar
Moderator Alumnus
Lightbulb 03-013: TQI of the DVD Navigation System With Voice Recognition.
rets's Avatar
Moderator Alumnus
Lightbulb 03-012: Immobilizer System (Type 4).
Old Mar 31, 2004 | 02:16 PM
rets's Avatar
Moderator Alumnus
Arrow 04-015: ABS Indicator Comes On With DTCs 15, 16, 17, 43, and/or 44.
From VIN 19UUA6...4A000001 thru 19UUA6...4A034483
rets's Avatar
Moderator Alumnus
Arrow 04-019: Brembo Brakes Squeal With Light Application.
From VIN 19UUA65..4A000001 thru 19UUA65..4A044453
rets's Avatar
Moderator Alumnus
Arrow 04-006: Audio Unit Diagnosis. (Revised 10/19/2005)
rets's Avatar
Moderator Alumnus
Arrow 04-005: Driving Position Memory System Does Not Work.
If you get anything produced with VIN over 020000, which these days should all be well over that, most all problems have been corrected. And the tire thing as caball88 said above.
Appendix...
Thanks. cblackburn.
Old Mar 31, 2004 | 02:17 PM
rets's Avatar
Moderator Alumnus
Lightbulb 89-015: ATF Cooler Cleaner.
rets's Avatar
Moderator Alumnus
Arrow 04-039: Headliner Sags at Moonroof Opening.
From VIN 19UUA6...4A000001 thru 19UUA6...4A054045
rets's Avatar
Moderator Alumnus
Lightbulb 88-016: Battery Test Procedure.
rets's Avatar
Moderator Alumnus
Lightbulb 01-026: Updating the ECM/PCM (Revised Sept 20, 2005)
Old Mar 31, 2004 | 07:53 PM
rets's Avatar
Moderator Alumnus
Lightbulb 97-040: Keyless Remote Transmitter Information.
rets's Avatar
Moderator Alumnus
Lightbulb 96-009: Removal of Clear Guard Protective Film.
rets's Avatar
Moderator Alumnus
Lightbulb 03-024: 2004 Acura Paint Codes; 05-003: 2005 Acura Paint Codes.
rets's Avatar
Moderator Alumnus
Lightbulb 96-025: Navigation System Component In-Warranty Exchange/Out-of-Warranty Repair.
2004TL With Navigation System
Old Jul 22, 2004 | 05:46 PM
rets's Avatar
Moderator Alumnus
Lightbulb 99-010: Cutting Keys With the Exacts Key Code Cutter.
rets's Avatar
Moderator Alumnus
Tsb 04-020
I’ve attached this TSB (the first page of 12 totals) below in order to provide more detailed info to those early VIN 5AT owners who has their trannies recalled.
  1. As it states, 2004 TL 5ATs, From VIN 19UUA66..4A000001 thru 19UUA66..4A014224, will be affected, however, it also indicates that “Not all vehicles within the VIN ranges are affected by this recall…”, please call ACS or have your dealer to check its eligibility first.
  2. According to federal law, these vehicles cannot be sold or leased until they are repaired. If you buy a 04TL 5AT with the affected VIN, your car should be fixed and updated prior to selling to you.
  3. There is no external way to tell if a remanufactured A/T has been updated. Only computer records from Acura and dealership could tell if this 5AT has been installed the oil jet kit or replaced by the remanufactured tranny.
  4. Take a look the part “Vehicles with 15k miles or less” and “Vehicles with more than 15k miles”, the huge difference of works and inspections need to be done.
Old Jul 30, 2004 | 02:36 AM
rets's Avatar
Moderator Alumnus
Info of TSB 04-016...
Thanks. SFzip
Old Mar 10, 2005 | 01:30 PM
rets's Avatar
Moderator Alumnus
Exclamation Tsb 04-043...
Thanks Lore's generous with this information.
Old Mar 10, 2005 | 01:32 PM
rets's Avatar
Moderator Alumnus
Thumbs up
If anyone has the genuine TSBs from Acura, please post, thanks. We need more to build out database for everyone in this forum
Old Mar 20, 2005 | 02:43 PM
rets's Avatar
Moderator Alumnus
https://acurazine.com/forums/showthr...40#post1159140
Thanks DMZ.
Originally Posted by DMZ
Here Tiz!!!
This is what Acura of Manhattan had to do to fix what was the #1 annoying rattle pain in my side for 3,000 miles. To give you an idea how much Acura is aware of this problem, look at the Out of warranty note at the bottom of the left column.
Old Apr 3, 2005 | 11:55 PM
rets's Avatar
Moderator Alumnus
Arrow TSB 05-013: Safety Recall: Fuse Box May Cause a No-Start or Stalling Condition
https://acurazine.com/forums/audio-video-electronics-navigation-22/bose-speakers-4-sale-112766/
Thanks, Randy.
Old Apr 3, 2005 | 11:58 PM
rets's Avatar
Moderator Alumnus
Arrow TSB 04-036: HomeLink™ Unit Does Not Learn The Garage Opener Code
Thanks, Randy.
Old May 27, 2005 | 07:18 PM
rets's Avatar
Moderator Alumnus
Exclamation TSB 05-017: 5th Gear Vibration or Drone.
Old Dec 2, 2005 | 09:44 AM
Ron A's Avatar
Administrator
TSB 00-037 Brake Disc Refinishing Guidelines
Old Dec 2, 2005 | 10:58 AM
Ron A's Avatar
Administrator
TSB 02-020 Initializing the OPDS Unit
Old Dec 2, 2005 | 02:13 PM
Ron A's Avatar
Administrator
TSB 03-033 MIL Comes On With DTCs P0301, P0305, and Possible P0300
Old Dec 2, 2005 | 02:20 PM
Ron A's Avatar
Administrator
TSB 04-004: Updating the Honda Interface Module (HIM) Model 3557-0100-00
Old Dec 2, 2005 | 03:04 PM
Ron A's Avatar
Administrator
TSB 05-003: 2005 Acura Paint Codes
Old Dec 2, 2005 | 03:19 PM
Ron A's Avatar
Administrator
TSB 05-014: Child Seat Anchor Locating Button Is Missing (Revised 06/07/2005)
Old Dec 2, 2005 | 03:25 PM
Ron A's Avatar
Administrator
TSB 05-020: HandsFreeLink (HFL) System Does Not Work (Revised 09/23/2005)
Old Dec 2, 2005 | 03:43 PM
Ron A's Avatar
Administrator
TSB 05-025: Outside Air Temperature Gauge Reads Inaccurately
Old Dec 2, 2005 | 03:51 PM
Ron A's Avatar
Administrator
TSB 05-029: Product Update: DTC B1161 with O/S Air Temp --- or Intermittent Dead Btry
Old Dec 2, 2005 | 03:56 PM
Ron A's Avatar
Administrator
TSB 05-032: 2006 Acura Paint Codes (Revised 11/05/2005)
Old Dec 2, 2005 | 04:04 PM
Ron A's Avatar
Administrator
TSB 05-033: Power Mirrors, Auto Dim Mirror, Pwr Seat Posn Mem, & W/Washer Not Working
Old Dec 2, 2005 | 04:18 PM
Ron A's Avatar
Administrator
TSB 05-034: 2006 TL: TQI and New Model Information
