Trying to get a TL
Trying to get a TL
I've been searching for a couple months now. I currently have a 97 3.0 CL. I've bene eyeing this http://www.autotrader.com/fyc/vdp.js...standard=false one down. What do you guys think?
I need a car in
1 Post
type s can be for some but if money is a issue like for me i sticked with my base and navi....buying a 20k car isnt something that everyone have =[.
that car is a ok deal. i paid 16.5 total for my 05 black on black 74k with navi. so maybe that is a price to base around.
Under construction
Looks pretty clean. Check the history, take a test drive and make sure the tranny shifts smoothly. I don't have a navi and I don't really miss it either.
Price is a little steep as well. That's what they want to get for it but you could knock off at least another grand. Good luck!
keep in mind that service gets a little pricey in this milage range (if you do a lot of driving). Also I have 1 with nav., it is cool, but if you have a little money after market deck, woofs and amp can be an option instead of the extra cost of a tl with nav. just my w2![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
good luck
good luck
good luck
good luck
Has anyone tried to install a unit http://orangecounty.craigslist.org/cto/1392334217.html like that?
good luck
good luck
At 105K, you'll have the timing belt, water-pump, valve adjustment and new plugs needed. This can cost a pretty penny. Another cost is usually tires, but since the description says it has new tires, you wont have to worry about it. A new battery may be needed soon, that'll be probably 100 dollars. Also there will probably need to be a brake fluid flush, coolant flush (5 yrs old), transmission fluid change ( 3 x 3 method), filters (cabin and engine) which can run about 400 dollars total. I say try to talk down the price a little bit and as well try to get some service history so you can better spend your money.
Thanks for the advice.
