Trunk Storage Organizer?
Does anybody know of a trunk organizer that would work for a 07 TL-S? I would like to find something that will fit in the forward section of the trunk to keep everything secure and out of the way. I already have the cargo net.
I have the trunk tray and it certainly was annoying trying to keep a plastic rectangular container stationary inside that tray at the top right. I finally drilled a hole in the top and right side of the tray and put a bungee cord around the corner of the plastic container. As the bungee cord would work its way down, I drilled 2 holes at the corner of the container and placed a stay tie around the cord. A lot of aggravation, but it’s been fine for years now.
Universal Cargo Organizer with Adjustable/Removable Dividers
My wife's Pontiac G6 came with this as a dealer add-on, and when we traded it in we took it out of the trunk. It just so happens to be a PERFECT fit in the TL trunk side-to-side. It's WAY better than a cargo net...holds grocery bags, bottles, you name it, and everything stays upright. Very rigid and strong. Folds flat (about 1.5" high) when you need more space for large items and comes right out of the trunk with a handle any time you need even more space. You can use it with or without the two center dividers as needed. I really love this thing!
NOTE: If you have a TL with NAVI, it is a snug fit L-R. I Don't think it will sit flat in the trunk if you already have a trunk liner.
OUT OF TRUNK
IN TRUNK, FOLDED
IN TRUNK, OPENED
GM Accessory number 12498559. It's available from any GM dealer but you can get a better price online, for example from this GM Parts Dealer:
http://www.gm-parts-dealer.com/parts.htm
OUT OF TRUNK
IN TRUNK, FOLDED
IN TRUNK, OPENED
https://acurazine.com/forums/3g-tl-2004-2008-93/alternative-acura-trunk-liner-gm-623359/
Bearcat that thing looks great. I found something very similar to it at Bed Bath and Beyond. Mine looks like the last pic you posted with the top off. It's modual so I only used 2 baskets and pushed it all the way forward. The net keeps it in place and all the junk in the trunk stays put.
Cool.
I knew from reading your original post that this might not be what you were looking for since it can't be pushed forward, but I thought others browsing your thread might be interested.
BB&B was probably less expensive too.
justin.w13.walker
Sep 22, 2015 02:21 PM
