Is it true that the TL logs everything?
Team NightHawk VP
is it true that the TL has OBD(i think thats what its called) and it logs everything you do and the dealership can just hook up the scan tool and find out top speed, top rpm, and whether or not you had tire spin or not?
i want to make sure because my car is going in for service for the flatspotting and i have been doing some spirited driving, and some wheel spinning was involved.
thanks
Cliff
thanks
Cliff
thanks
Cliff
thanks
Cliff
Life is good.
Cliff
Cliff
Team NightHawk VP
its spirited drivingm not spirted driving you silly lol
just messin with ya
Cliff
but does anyone know if thats true or not, because the warrenty doesnt cover tire spinning
just messin with ya
Cliff
Life is good.
Dude, I wouldn't worry about it, it very unlikly that they could tell that you smoked the tires, unless you did it on the way over to the dealer or something.
Team NightHawk VP
thats what i thought until i saw the tread, it was totally different from the rear. i dont know how to explain it but you can tell the difference
Moderator Alumnus
A few months ago, there is one thread talking about the similar thing, the car's black box, not this OBD.
IMO.
The 04TL is definitely having OBD stuff, which could help dealers dignoses your car's issues. But how far will this system go and how varieties of data will this system record? we don't know... There are dozens of engineers in our forum, they may have better clues.
This should not be like Car Data/Info Recorder, the black box of your car.
Can I say no one should use this OBD info to go against you?
IMO.
i remember on the bmw forum someone mis-shifted from from 5-2, the person wanted to downshift to 4 but put it into 2 but accident. he blew his engine and took it to the dealer for warranty. they hooked up the computer to the car and read that the car was rev'ed to 8200rpm (red line was like 6500ish) and denied warranty work to the engine. so the blackbox can work against you.
The TL's black box is extremely unprivate. For example, it sees you when you're sleeping. And I believe it also knows when you're awake. For certain it knows if you've been bad or good.
So my recommendation is to be good. At least, for goodness' sake.
This is in the manual, pp. 876-878, under the topic "You Think You Gonna Fuck With Acura? Acura Gonna Fuck With YOU!!"
It videos everything you do in the car also. Little known fact. Small camera in the headliner. The headliner falling down allows the dealer to download the video when you take it in for repair. Clever of those Honda engineers. Aren't you all embarassed now?
Moderator Alumnus
Is it possible that BMW device just recorded the final key sequence of events causing the problems? That's why BMW could diagnoses that issue againt the client. If you're in safe driving (never blow out your device/system), they should not be able to record anything... I guess...
Who has OBD reader now? You may check it out if you can see High speed/high RPM info out of your ECU...
thanks
Cliff
thanks
Cliff
Team NightHawk VP
Originally Posted by jrogers345
Flatspotting??? Which tires do you have? You just got the car so I thought you wouldn't have that problem?
thanks
Cliff
thanks
Cliff
Originally Posted by Tread
caball88, if that were true, then the rev limiter in the BMW did not work, and it was the failure of that component that blew that engine, not the person, you know, before all this electronic crap, then it would have been your fault, but big brother stops you from doing stupid things, just like VSA, DSC, VSC, etc. stops you from hanging turns too fast.
Moderator Alumnus
this is a manual tranny and it was spinning at 3-4K rpm in 5th gear. when you drop the car into 2nd gear it will spike up to 8K+. it has a rev limiter meaning it cuts the fuel to the motor and will stop it from climbing higher. doesn't mean it prevents a mishift and stop the rpms from jumping over the redline. think about it if 5th gear ratio is <1 and 2nd gear is 2.5ish and the rpms were at about 3500 you multiply it by 2.5 just for rounding sakes you get 8K+ rpms. there is no device to stop the flywheel from spinning past 8K. once you drop the clutch its all over. you must be use to them automatics huh?
You may know this guy driving his BMW at speed approximately between 100 and 140 MPH at 5th gear/3-4k RPM.
I don't know how the manual tranny works... BUT if you drive 5AT 04TL, at 5th/140 MPH, we can say the ECU would not let you downshift to 3rd; at 5th/100 MPH, you won't be able to down to 2nd . Quite safe, right?...
:smokin:
FYI, I have been driving a clutch for over 30 years, never had that happen, and I drive pretty hard.
No reply or flames needed.
thanks
Cliff
thanks
Cliff
Actually, if the guy is that over the edge that he doesnt release the clutch or doesnt know what gear he is in, or going to, then he deserves to blow an engine.
This is the first time in a long time this forum has actually made me laugh out loud. Bravo TLGator!
Moderator Alumnus
caball88,
[/size]
:smokin:
:smokin:
not sure if the bmw's had this feature but my 1991 nissan 240sx didn't have this feature i was able to get it into 2nd gear from 5th. i didn't release the clutch but i was able to shift into it. the TL has an electronic lockout for reverse when you are moving foward. actually i don't think the TL has a lockout from 5th to 2nd.
ok i can't find the thread on the bmw message board but here is one from an RSX board. the person went from 5th to 2nd and blew his engine like the bmw.
RSX 5th to 2nd misshift
there were pictures but they are not there anymore. it would look like a bunch of metal parts in an oil pan.
Two things....
First, they just had a report on TV of Harris County Sheriffs taking data off the black box on accidents. It gives them a LOT of info including braking, speed, wearing seatbelts etc. It only keeps the last 5 seconds of data, but that is enough on an accident.
Second, I do not see how someone can 'mistake' shifting into second. The syncros would not like that and it would require a lot of force to get into gear (my opinion) as opposed to fourth. I can even feel that the TL does not want to go into second easily at 40 when downshifting.
but it will go into 2nd won't it?
sorry that last link was dead
http://forums.beyond.ca/showthread.php?threadid=16883
I agree with Formula 350. On the rare occation that I missed the 4th gate and hit the 2nd gate during a downshift from 5th, my syncos would start to wind up and I knew I was starting to miss my intended gear.
I find the bmw 5th to 2nd gear story hard to believe. It would take a lot of force and complete disregard to what your car was telling you to drop your clutch in the bmw situation that was discribed.
what about the RSX 6th to 2nd story then? that was recent and it was also an acura. there were pictures posted but i guess the host is no longer up. but if you were able to see that the engine was completed destroyed. i'm just telling you what i read on the forums. it didn't happen to me and it was not someone i knew.
