Transmission Fluid in Radiator & Overflow Tank
Old 10-26-2020 | 01:13 PM
JeffHP's Avatar
3rd Gear
I'm new to this and need some advice.
I found my 2008 TL leaking transmission fluid and coolant out the overflow tank. I checked the transmission fluid level and it was barely on the dip stick. I assume the radiator transmission cooler leaked internally into the engine coolant. I obviously need to replace the radiator. Is there anything else I need to replace? Transmission filter, radiator hoses, thermostat or water pump?? I found a Denso radiator on Rockauto.com for $131.79 (#221-3241). Is this a good radiator for the TL?
Any advice is greatly appreciated.
Thanks - Jeff
Old 10-26-2020 | 01:17 PM
truonghthe's Avatar
OEM radiator is Denso, as far as the ATF. I would check to see if the color being mixed with coolant, if it does perform drain and fill until you see pure transmission fluid.
Old 10-26-2020 | 01:22 PM
JeffHP's Avatar
3rd Gear
Do you recommend taking it somewhere and have the cooling system flushed out before replacing the radiator?
Old 10-26-2020 | 01:38 PM
truonghthe's Avatar
you can do the flush at home, just run a house through the engine coolant inlet and watch it come out the outlet (remove the thermostat) and make sure you disposable coolant properly. I would worry about the transmission at this point.
Old 10-26-2020 | 02:39 PM
JeffHP's Avatar
3rd Gear
Ok. Thanks for the recommendation!
Joneill44
Sports Talk & Fantasy Leagues
1073
02-08-2021 02:12 PM
Roundeye
1G TL Problems & Fixes
04-22-2011 11:14 PM
nickbeee
07-06-2007 08:21 AM
yunginTL
04-25-2006 10:20 AM
Quick Reply: Transmission Fluid in Radiator & Overflow Tank
