Transmission Bolt Thread Pitch
This is going to be a reach but I figure I would ask.
I pulled my upper transmission mount to do the pressure switches and 3x3 on my 07 TL base last night and of course one of the bolts was seized in. I did end up getting it out but it now had pretty messed up threads in the hole and on the bolt. I have a chaser kit but none big enough. I called and ordered a bolt from acura but I was wondering if anyone knew the thread pitch so I can buy a tap or chaser.
On another note does anyone have any input on using a Nickel based anti seize on this bolt? I know its a stainless bolt going into aluminum so it have the anti galvanic corrision on it but this is the 4th time I have run into an issue like this on a Acura (You would think a company like Acura could get this figured out).
I may run to the hardware store and just get a stud and nut, that way if it seizes again the nut will still come off.
The bolt is #51 in this diagram:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
All it gives me is 12mmx40mm no pitch.
I didnt have to remove that bolt but the sensor is right under that mount so I was trying to make my life easier... Oh well.
And thanks JJH, I figured it was 1.25, most Honda/Acura bolt are.
justin7779
Dec 25, 2015 10:33 PM
