Trans flush w/ cooler lines method??
Is this how it supposed to be done? I googled and found this so not sure if it would work the same way for Acura.
- Remove both ends off the cooler
- place one end in a bucket (old fluid)
- Place other end in FRESH ATF (8 quarts or so)
- Start Car in neutral
- Run until most fresh ATF has run through system or sooner if fluid
appears clean (cherry red).
- replace lines on cooler
- top off with ATF and test drive.
Is there any DIY thread with pictures on here? I'd love to do this since it's both safe for Acura transmission and not have to do 10x10 d&f
to get most of the old fluid out... Any input is appreciated!!!
One side of the cooler is pressure and one is not. The hose that's not pressure is not suction. You can stick it in a fresh bucket of oil but it's not going to do anything.
The correct way is to do a drain and refill but don't start the engine. Stick the cooler hose in an empty bucket. Start the engine and fill while the engine is running through the usual fill hole on top of the trans.
Plus, if it's that simple, why so many people are doing the 3x3
it gonna takes 10x10 to replace as much old fluid as 1 tranny cooler flush
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
