Trailer Hitch and ASpec
'06 Acura TL
I know there are a bunch of threads about hitches and bike racks. I read through them all. And several of them ask the question:
Will a hitch work with the ASpec body kit without modifications?
Please don't stone me...
I went to the dealership and they said that its not recommended with a auto, but I have a 6speed and the guy said, "You didn't hear it from me but its ok with the maunal transmission."
I want to use it to haul my GSXR750 to the track and also when I travel from PA to FL.
Pictures would be awesome.
Thanks!
Thanks!
'06 Acura TL
Originally Posted by erick3
definitely wouldn't recommend but eh...are you dropped?
Honestly I think the ASpec springs would be better cause they are harder and stronger than regular springs therefore handle more weight. Cause I LOAD my trunk and entire backseat when I travel from PA to FL, which probably totals about 600-700 pounds worth of stuff and it drops the back end a little less than inch I think.
So a trailer with is a couple hundred pounds and my bike is only 325. Thats honestly all that would be on it.
'06 Acura TL
Originally Posted by MWalsh9152
the only real way to find out the answer to this question is going to be putting the car up and attempting to fit the hitch in place.
Thats what I was afriad of...
邵樂百
'06 Acura TL
Originally Posted by firstacuratl
Just a quick question....how the hell did you get your Gixxer 750 down to 325 lbs.? That's frickin' light! Even with Sharkskins and gutted my Gixxer 1K weighs 352 lbs. with 2 gals. of race fuel on board
邵樂百
Well, it comes stock at 359. Replace the entire stock exhaust, take off the radiator and put race fairing on it...that'll do it.
I hope you mean oil cooler removal, cause I don't think I could manage w/o my radiator.....Spokane Raceways gets hottttttttt
Apologies to mods for getting off the "3G track".......signing off this thread.
'06 Acura TL
Already done all that...Akrapovic Evolution II, Ti header+CF can, Ex-valve delete, PC III USB, Sharkskins....etc.
I actually don't have a Power Commander. Don't really see the need. Mind you I've only ridden on technical tracks where I barely get into 4th on the straights. And when you're running with 600s, my 750 has more than enough power.
Anyway...No one with an ASpec Package ever got a hitch or did research for one?
邵樂百
I was j/k...knew you didn't remove the rad. Spokane Raceways, after turn 11....WFO for almost exactly 1 mile! Radared at 181 before entering turn 1....the PC comes in handy when those pesky ZX-10's come sniffin' around...
Here ya go man.....same style hitch I had on the Cobra. Draw-Tite Hitch for 06 TL
Disclaimer:You'll definitely have to confirm it will clear the A-Spec rear body spoiler
