TPMS is a bit annoying in cold temps
For the past week now we've been getting some cold weather. Every morning when i start the car, the TPMS warning lights up for the two front tires. The funny thing is that the readings for all four tires is about 28PSI (according to the MID). I always take a quick glance at it and it looks fine (the front two that is). Now what I do is pretty much ignore it because after driving around for a while the warning light goes away. Could the TPMS just not perform correctly under cold conditions?
The ideal gas law states that pressure is directly proportional to temperature if the amount of gas (i.e. number of moles) and volume inside the tire remain the same:
pV=nRT where p=pressure, V=volume, n=number of moles of gas, R=gas constant, and T=temperature in kelvins.
Therefore, when your tires are very cold, like when you first start your car in the morning, the pressure will read lower by the TPMS. However, after you've been driving for a few minutes, the tires become significantly warmer due to heat imparted on the tires by road friction and sidewall flexing. After the tires warm up, the pressure increases above the threashold that the TPMS considers "low pressure".
In conclusion, your TPMS is functioning properly. Add more air to your tires.
Been in the single digits all week where I'm at and I've never had that problem. I had my car through the entire winter last year, and never saw the problem as well. Sounds to me like you need to check your tire pressure and give them some more air when cold to bring them up to the cold tire pressure.
I had this issue a few weeks back. Mine were reading 28s and 27s. I simply added more pressure (32 psi) to the tires and the problem went away.
If you switch to Nitrogen gas, then you can prevent the variations due to temperature.
Just had the same thing happen... got cold (19 yesterday- brr!) pressure dropped to 26 in the rear cold- 28 after a bit of a warm up drive...) .... stopped at the service station and bumped up the pressure.... was happy to have the tpms tell me about it.
Though I can see if the temps in your area spike from 20 to 60 over and over that you might get annoyed the tpms makes it easy to always have the right pressure.
Adjusting the tires take 2 or 3 min at most... It might sound crazy- but I actually use my bike pump when it isn't 19 degrees outside to adjust pressure. Perhaps a bit strange- lol.
^^ what he said
I've been to gas stations, where when you spray the air, water droplets actually spray out with the air.
That's one of the reasons I bought my own air-compressor. (That and the tools). I put on a line-dryer on my air-hose. I don't get the fluctuations in tire pressure any more.
Unregistered User
Originally Posted by TriniBwoy
Well professor Desert_TL, I'm not going to add more air to my tires because although it's winter, the temperature fluctuates alot so I don't want to have too much air in the tires. Besides, MID reports safe PSI readings after driving it around a bit.
Retired and Loving It
Originally Posted by leedogg
I would say your front tires are on the borderline low side. Pump them all to 32 when they're cold.
for every 10 degrees that outside temperature decreases tire pressure will drop one pound. acura calls for 32 lbs when tires are cold so add air as the outside temperature drops.
the number one reason tires blow out is due to heat build up caused by under inflation.
Originally Posted by Pat D
Bad idea. The 32lbs is required when COLD, not warmed up. Always fill tires cold. Even tires backing in the sun or on hot asphalt will give inaccurate readings.
Sorry to sound like a simpleton, but isn't the general rule (and isn't this published in Acura tech pubs) to always measure tire pressure when the tires are warm? So if the TPMS is registering low (and you don't appear to have a flat tire) and you drive a bit and the pressures come up, everything's pretty honkey dorey.
Mike's Silver Bullet
The rule has always been to check cold.
Add a couple or 3 psi if they are warm; i.e. set to 35 if you want 32 when cold.
You guys got me thinking...
At first thought, nitrogen or dry air shouldn't make and difference in the pressure variation over temperature. pv=nrt is the universal gas law.
On second thought, maybe the vapor pressure of the humidity in the air is the cause of the difference. The water precipitates out when it gets cold (it snows or rains in your tires!), so the vapor pressure contribution from the water drops.
Wow, I learned something today.
Whoo Hoo!!!
Mike
Whoo Hoo!!!
Mike
You guys are getting way too technical. The people who are saying the tpms is inaccurate in cold and extremely hot climates are wrong, it's always accurate. It's how the temperature affects the pressure inside the tire. However, if you have a warm air pressure reading somewhere around 35 psi, excessive heat will never cause the pressure to reach dangerous heights and vice versa.
Air Vice Marshal
I've seen several posts saying you pump them up to 32 cold. The recommended pressures on my '07 TL-S are 35 front and 32 rear. Since the TPMS will go off at 20% below the standard pressure, that's 28 for the fronts. My car was delivered with low pressures. The next morning I got the tire pressure error when I started it. I just pumped them to 35 and 32 and they've been fine since.
It's a basic, albeit annoying, fact of life that we need to check and adjust our tire pressures to compensate for seasonal differences in most parts of the country.
Putting the fronts up to 35 where they belonged also helped the handling.
I got mine in december and I live in the north east where we've been having weather all over the place. The dealership couldn't have checked the tire pressure to regulate them because my front right was near 40 and my front left was 30/28 depending on the weather. I first noticed it on a cold day when the TPMS warned me about the front left being low. I was pissed when I saw how fucked up all he pressures were. The dealer owed me a detail so I told him to regulate the air pressure. Moron forgot to tell the service guys so I had to do it myself.
Also, when I did my own detail of the car (dealership details blow) I noticed some nicks in my paint (I bought an 06 demo). Did any of you guys get toch up paint with your purchase? Since they never touched up my car during the detail I'm tempted to go over there and demand they give me a bottle.
Be kind to us truckers !
Originally Posted by jptl04
even if you remove the sensors, the TPS alarm will still go off. i don't think there's a way to disable it. correct me if im wrong.
This wasn't on my Acura. I removed them on my Nissan Titan. The truck had a little bit different system on it and with the sensors removed the alarm wouldn't sound although the light would eventually come on after the truck was running for around an hour without getting a signal from the sensors.
Originally Posted by avs007
That's one way to do it. However, the reason why you are probably getting such fluctuations in your tire pressure, is the moisture content in the air. A lot of places don't bother putting in-line dryers on the lines, nor do they bother to drain their air-tanks...
Bone stock tl-s
Originally Posted by niti
Can you tell me more about the "line-dryer" apparatus? Where to buy, how much etc. That sounds like a great idea if it's fairly inexpensive. Is it something that you just pick up at home depot? Did a search on the home depot site and came up empty.
found this on ebay is this similar to the one you bought?
http://cgi.ebay.com/ebaymotors/AIR-W...QQcmdZViewItem
Originally Posted by bumski667
use nitrogen
Also, the weather has been quite nice these past few days, so now I have a higher PSI reading from MID After driving around on the freeway, the PSI get as high as 37 PSI, does anyone know if this is a dangerous level? Is there some set PSI we should not exceed?
Thanks.
Excuse my ignorance, but what's the benefit of using nitrogen.
Thanks.
Thanks.
"Here are a few other benefits of using Nitrogen in tires:
[1] Nitrogen is denser than Oxygen: This means the larger
molecules escape less easily from tires resulting in a more
gradual loss of pressure over time. According to the Michelin
Tire Manual, a tire that is inflated with Nitrogen loses its
pressure 3 times slower than if it were inflated with air.
[2] Nitrogen is moisture free: Pure Nitrogen inflated tires
experience less steel belt and rubber degradation. Nitrogen use
also reduces valve and wheel corrosion.
[3] Nitrogen provides longer tire life: Nitrogen inflated tire
run cooler and require less maintenance according to the Goodyear
application bulletin.
[4] Nitrogen is non-flammable: Nitrogen technology has been used
in aircraft, military and race car technology for over thirty
years."
You should be just fine with 37 psi, it's not enough of a difference to cause any abnormal wear and it's well within the safety limits of the tires. If it bothers you, go ahead and take them back down to your normal pressure for peace of mind.
*Didn't edit in time*
It's not worth the trouble of running pure nitrogen if you ask me, we have a nitrogen generator at work and if I have a low tire at work I'll go ahead and fill it there, but I won't go out of my way to do it. I've never had a tire that rotted out before the tread was worn down and I've never had a problem with corroding wheels. I bet most shops that sell you nitrogen for your tires are only using nitrogen that's about 95% pure anyway.
Thanks.
Thanks.
Air Vice Marshal
Originally Posted by MisterFubar
Here is a quick and dirty answer on why you can use nitrogen.
in aircraft, military and race car technology for over thirty years."
The other thing to consider is reality.
a) You already have almost 80% nitrogen in your tires. Air is mostly nitrogen.
b) The nitrogen you're buying won't be pure. Often it is only 95% or so, about the best from your typical gas station membrane generator. .
c) When you "fill" your tire with nitrogen, you are starting with a tire that is already full of air unless you use a vacuum pump to suck it all out first. An empty tire contains a volume of air at 1 atmosphere, almost 15 psi. To make your tire gauge read 30 psi, you pump in two more volumes. So, your tire contains about 90% nitrogen, or about 12.5% more than you started with.
Bottom line, for passenger cars it's really just a gimmick to make money.
