Top speed for a TL
#81
Originally Posted by ayethetiense
you are about a year late on the response there buddy
and in response to this thread, i hit about 235mph in my TL, my penis is 18 inches long and i can pee about 12 yards away
#83
AZ Community Team
Originally Posted by RVC
I've had my TL up to about 85!!!
Here's Road and Track's test results for a 2004 6MT
http://www.roadandtrack.com/assets/d...2004172540.pdf
#85
Originally Posted by ndx2
Just a reminder - whether these 155'ers are lying or not, don't attempt at this with stock rubbers... neither the EL42's nor the MXM4's are suitable for a stunt like this.
#87
Originally Posted by pohljm
not that I would attempt a sustained run at 155, the factory MXM4's are rated to 168 mph maximum
Do you just like to argue or what?
Are you saying you'd be comfortable going 150+ with those MXM4's?
#88
3.2 VTEC
I am here to break all the myths In my 2002 3.2TL Type-S, the top speed limiter was as the speedometer read, 147mph, I am sure because I have hit it at least 3 times. In my 2006 TL 6MT, the top speed limiter it at an exact 150mph, and no more. Since the 6MT TL gets up there so easily, I have bounced off of 150MPH atleast 15 times by now, and no it's not 151 or 155 or whatever, it's 150 exact i even made a video so i can look closely afterwords it's at an exact 150.
Other car governers i have tried is a 2004 Honda Pilot, which is sumwhere between 108-109....and a 2000 Toyota Camry CE 5MT, which was at 115.
If someone claim that they did over 150mph in a 2004-2006 TL without taking out the governor, than that means mabe the earlier years had a higher limiter than 2006.
#89
I hit 149 in 6th gear when I owned my TL
http://img35.imageshack.us/my.php?image=johntl1zq.jpg
and no way in hell would an N/A R1 hit 200mph....mine is highly modified and I cant even hit 185
#90
I have nailed the speedo at 160 but it takes a minute to get there. All i have done is the "mid" muffler removed and an intake with the "off road" temperature sensor moved to the intake.
#92
I've only hit 120, I still think it can keep going. my car is completely stock so wit some mods it might have more potential. has anyone wit a supercharger in there car 150 or more?
#93
My 06 TL only has 600 miles on it so far, and the fastest I have driven is 75 mph. When the odo hits 1200 miles, I think I will be driving twice as fast, ie at 150 mph. Simple math
#94
#95
:sigh:
#96
Ratings don't mean shit on these tires; if you wanna get technical, fine. I was being realistic and gave a reminder accordingly for the sake of people's safety, because so many people come online and post ridiculous BS.
#97
AZ Community Team
If the tires are rated for that speed, load, and the proper inflation then there's no safety problem from a tire point of view.
However going that fast on the street is just foolish and stupid, we all know know there is an incredible list of safety issues you deal with. It's just not worth the risk to you and others on the road. If you want to go that fast go to a track.
#98
Originally Posted by Final
150 last night with 19's on.
#100
Your statement would lead people to believe that they could save some money and mount up a H rated tire on their TL and be safe because......... "the ratings dont mean shit" So if you truly are looking out for other peoples safety and not just trying to argue, I suggest that you take your own advice, and dont post rediculous BS
#101
you are to funny......talk about posting rediculous BS. "the ratings dont mean shit" OK I supose the manufacturers just toss out a letter that sounds good at the end of the tire sizing string and it has no bearing whatsoever on the capabilities that have been engineered into that specific tire. Let me assure you that is not the case. The engineering department will ensure, and the legal department will demand that the tire perform up to its rated speed.
Yeah, the ratings will stand true if they were tested in optimal condition; I've driven on EL42's and MXM4's, and they weren't very stable at higher speeds.
At 150+, these tires could turn a slightest mistake into a major disaster, whereas better tires could be more forgiving.
I didn't feel safe at all even at 80, 90 MPH on EL42's, and I was giving my opinion based on my experience. Since I've switched tires to Ecstas, with same W ratings as the EL42s, and have felt a huge difference in traction and overall stability at higher speeds.
#102
I said ratings don't means shit with THESE specific tires, the EL42's and the MXM4's, which aren't much for traction or performance.
#103
'17 RDX Tech AWD - WDP
Yes, the tires are crap. And, yes, you could end up dead with one little mistake at 150 miles per hour. But, that isn't a reflection of the tire's traction.
As for tire ratings, the speed rating has a lot to do with whether or not the tire can handle the cetrifugal force and amount of heat generated from driving at a specific speed for a duration of time. If you take a "S" rated tire and drive it 140 MPH for a quick burst, you might come out of it ok. But, your tires would completely disintegrate if you tried to maintain that speed.
#104
Originally Posted by trancemission
I dont think I will ever take mine that fast....
I second that the highest I have ever had it was 120 on I-10 going back to Jacksonville Florida. The highest that I have had it here in Italy is about 80-95 which very bad because of how unpredictable the driving is here and the curvy roads. I have to slow down I fear that I will be in a very bad accident before I leave Italy.
#105
#106
Received 2,600 Likes
Originally Posted by Twenties
Mine topped out reading about 155. According to Road & Track it is electronically limited to 147 MPH. Without the limiter I bet it would reach mid 160s. When I hit the limiter and it read ~155, the RPMS were NOT close to maxing out.
#107
Best Generation of Acura Grills
Just curious to know what people thought of as the best headlight/grill combination there is of the 3 generations of TLs. I really love and admire the second generation headlight/grill combination. I really think its looks the best. As for the third generation, the grill is nice but the headlight aren't as aggressive as the second gen.
What do you guys think
'02 - '03 TL is the best looking by far, at least the front part anyway.
#108
#109
2007 TL Type-S
i hit 135 and then started to bring it down cuz there was a curve coming up. coming through the curve a cop clocked me at 82 mph, my boy told me if i had gotten clocked at 135 i would have gotten arrested (is that true). i know the car had more in it but i got a little nervous; at least i got it kinda outta my system.
#110
Back in a TL again.
i know hitting 3 digits is wreckless driving and up to the cops discretion to arrest you ive done 147 in the tl and 178 + - on the spedo being off on my 03 r1
09-17-2015 09:01 PM
