tls headlights in an 04 base?
Hey Guys,
I did a quick search and didnt get any clear answers on this, but ill 07 type s headlights work on an 04 base tl and if so what needs to be modified?
Thanx for helping out the 3rd gen newbie!
Tails are a direct swap.
Headlights require:
* different size ballasts,
* 9005 inner lense bulb (don't use a regular bulb because the heat will melt the housing at full power),
* 1157 parking/turn signal bulbs,
* 1157 type-s socket, and
* electrical connector for the 1157 socket.
Headlights require:
correct me if i'm worng but aren't the 9005 the running lights?? so if someone wants to install the 9005 ineer lense bulb, the person will only use them during the day, right??
Rev High; Drive Happy
9005 and 9006 use the same pigtails... but the tabs are angled differently.
Some members, however, have noticed melted shrouds/housings for the DRL/Fogs though...
Former Sponsor
You could have sold your 04 ballasts and bought 06 and maybe didn't have to pay anything. I wouldn't cut corners anywhere, it always comes to bit you in the ass later, but thats just me. All you need is moisture to get in the headlights and ballast and blow your whole set up, then you will be pissed that you didn't spend around $30 difference in the two for a $300 repair.
mlody
12-04-2019 02:11 PM
AmplifiedDetails
09-24-2015 02:55 PM
