TL vs. Chrysler 300C: Round 2
#81
Originally Posted by TLover
You are right, you weren't quoting the Combined Gas Law, but ...
http://acura-tl.com/forums/showpost....1&postcount=85
#82
Originally Posted by Skeedatl
And V in the BERNOULLI EQUATION IS VELOCITY!!!!!!!!!!!!!!!
Click and see:
http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html
#83
:lol1: Now you're saying that p1v1=p2v2 is Bernoulli's equation? What are you, retarded?
![](http://hyperphysics.phy-astr.gsu.edu/hbase/imgmec/bernoul.gif)
Bernoulli's equation IS NOT p1v1=p2v2 dumbass! p1v1=p2v2 is the COMBINED GAS LAW!!!!!!!!!!
This was your ORIGINAL stupid claim
Originally Posted by Mullethead
An air scoop moving @ speed in a ram air system slows the air; it acts as an "air brake."
That results in higher pressure (@ the intake manifold).
P1V1 = P2V2
THAT is where the added pressure is coming from.
P1V1 = P2V2
#84
Originally Posted by harddrivin1le
Yep...you are correct. That was my big error.
#85
Harddrivin's philosophy: "I link, therefore I am."
The links have nothing to do with your statement, other than to illustrate how incorrect it was.
#86
Shoot me.
Either way, RAM AIR works. Air actually IS compressible below MACH 0.5. Many equations "assume" that it's not for the sake of SIMPLICITY.
This is the source of my error:
#87
Over simplified? What are you doing? The new math? THEY AREN'T THEY SAME EQUATIONS, NOT EVEN CLOSE!!!!
What's next, mass/energy equivalence is over simplified to PV=nRT?
Another stupid 1LE post brought to you by CTRL+C and CTRL+P.
#88
But neither are your claims regarding aluminum heads and ram air.
#89
But neither are your claims regarding aluminum heads, ram air and your assertion that I claimed V = velocity in the Combined Gas Law.
An understandable mix-up, I think, for someone who last took fluids 18 years ago:
#91
Oh yeah, aluminum heads can't run higher compression, ram air on the WS6 is anything other than domestic rice.
When you build a 300MPH Slomero, you can put ram air on it in get a few HP. But then you said it's only a cam only swap to get a POS Slomero into the 10s, so 300MPH is only another stick of super glue and a paper air filter away.
#95
Oh yeah, aluminum heads can't run higher compression...
And in that case, the more advanced version of your favorite law IS applicable in that less retained heat results in lower (cylinder) pressure:
PV=nRT
#96
Andrenaline Junkie
#97
Originally Posted by Swat Dude
Dude, you should see how long we went on the Chrysler thread. Where were you? HD proved that although he claims to be an M.E., he has no clue about thermodynamics and failed to answer an elementary question about psychrometrics although he was arguing in his typical fashion like he was the expert on refrigeration.
But the BASIS of refrigeration concerns the process by which the refrigerant is initially COOLED.
What occurs in the evaporator coils themselves is simple heat transfer, which is not attributable to "the combined gas law" as you claimed.
![Smash](https://acurazine.com/forums/images/smilies/smash.gif)
http://www.hodsonhome.com/mna2001/c...s/adiabatic.htm
Everything has an internal energy, even gases. When pressure is applied to a gas its internal energy increases because we are performing work on the gas. As the gas expands its internal energy decreases because the gas is performing work by expanding.
(1) D internal energy (D U) = heat added or removed (dq) + work done to or by the gas.
Since there is no heat added or removed, the first term (dq) = 0. So (1) becomes
(2) D internal energy (D U) = work done by the gas (dw)(ii)
When gas performs work dw is negative so the internal gas decreases. Intuitively since we know that temperature is an indirect measurement of energy, we can guess that the temperature of the gas will decrease as it expands. This decrease in temperature is the Joules -- Thompson effect.
This is how your refidgerator or AC works. A compressor (left side of cylinder) pumps a gas (freon) through a throttle and into a network of coils (right side of cylinder) where it rapidly expands and cools.
#98
Donald E. Vogel
In the evaporator, latent heat is absorbed into the refrigerant as it changes from a liquid to a vapor. In the condenser, the refrigerant changes from a vapor to a liquid as it releases latent heat. In each component sensible heat is also transferred, but the greatest heat transfer is in the latent state.
#99
#100
...ram air on the WS6 is anything other than domestic rice.
P.S. Bernoulli tells us that air does NOT have to compress in order to gain pressure!!!! That's because a DROP in Velocity produces an INCREASE in pressure. So your claim that Ram Air doesn't work because air "isn't compressible below Mach 0.5" is just plain ludicrous:
http://www.av8n.com/how/htm/airfoils.html
"Combining these, we conclude:
P + ½ ρv2 = Mechanical Energy per volume (3.3)
Next, we make the approximation that we can ignore non-mechanical forms of energy (such as chemical reactions or heat produced by friction), and that we are not adding energy to the air using pumps, pistons, or whatever. Then, using the law that total energy cannot change (see chapter 1), we conclude that a given air parcel's mechanical energy remains constant as it flows past the wing.
Now, if the right-hand side of equation 3.3 is a constant, it tells us that whenever a given parcel of air increases its velocity, it must decrease its pressure, and vice versa. This relationship is called Bernoulli's principle.
Higher velocity means lower pressure, and vice versa
(assuming constant mechanical energy)."
In fact, the claim that air doesn't compress below Mach 0.5 is itself ludicrous!
#102
Sigh. Can't we learn just to
each other
![Love](https://acurazine.com/forums/images/smilies/love.gif)
We can all agree once we become as enlightened as the person who made those statements.
http://www.lerc.nasa.gov/WWW/K-12/airplane/bern.html
#103
Not until we all "agree" that aluminum heads permit "vastly higher" compression ratios, that ram air is "a myth" and that air must compress in order to undergo an increase in pressure (despite the fact that Bernoulli tells us otherwise). :lol2:
#104
PROVE that the WS6 RAM AIR system was any less effective than the system used on that Kawasaki bike.
Go ahead genius...do the math proving that the ram air system on the WS6 builds HP in street applications. Of course since you claim it's only a cam only swap to get a Slomero into the 10's you should have to problem getting a WS6 to do 300MPH.
There is a reason air isn't considered compressable at slow speeds for computation purposes. It's because the amount of compression is nearly ZERO at speeds below Mach .5. Certainly not enough to build HP in a street application. I've already shown you the math why...you simply don't have the engineering and fluids background to understand it.
You obviously don't understand Bernoulli's Principle any more than you understood the Combined Gas Law. Bernoulli's Principle is not the physics behind "ram air".
LOL V is velocity in the Combined Gas Law ROTFLMAO...you are laughable. :lol2: :lol2:
Tell is all again how aluminum heads don't permit higher compression, how it's only a cam swap for a Slomero to get into the 10's, how cotton doesn't outflow paper filters, HID sucks, and how the center of mass on a small wheels is different on a big wheel.
#105
The math shows that ram air in the WS6 won't build HP. It's simply there to dupe mulletheads like you into buying plastic covered domestice rice.
#106
The math shows that ram air in the WS6 won't build HP...
Tell is all again how aluminum heads don't permit higher compression, how it's only a cam swap for a Slomero to get into the 10's...
This "Cam only" LS1 is EXACTLY how I told NORSE396 it was - cam as the only INTERNAL engine mods and a lightened car with bolt-ons (but normally aspirated). That you misconstrued it to mean something else is YOUR error:
#107
Answer: Static Pressure RISES!
2) What happens to the velocity of the air as it makes it's way from the ram air intake and through the intake tract?
Answer: It SLOWS
![Flash](https://acurazine.com/forums/images/smilies/flash.gif)
#108
What happens to STATIC PRESSURE as velocity slows?
#109
Correct me if I'm wrong (it's been a LOT of years since I took aerodynamics/thermodynamics), but that assumes all the fluid (air) in the system remains in the system. Bernouill's Principle explains why airplanes fly. In a ram-air system, doesn't the increase in pressure at the inlet divert fluid (air) away from the system?
RAM AIR obviously "works," as was readily demonstrated in this real world test (both on a dyno and on the road/drag strip), It's effect isn't "huge," but it is quantifiable at speeds that are readily approachable in today's performance cars (and bikes).
It was good for a ~ 2% boost in power in this bike @ 100 MPH.
It was good for a ~ 7% boost in power in the same bike @ 150 MPH:
http://www.sportrider.com/tech/146_9508_ram/
#110
Donald E. Vogel
Great engine that LS1; pulls from idle and extends torque to a high enough RPM to develop some good power; in a robust lightweight fuel efficient package.
:diablotin The god-damned fools should have used it in the Catera in 97 when the LS1 came out, mated to a T56 and the rear suspension from a C4 adapted to a suitable rear subframe. It all would have easily fit with only minor changes to the body. The car might have sold, without dragging down the CAFE numbers. The GTO is 3/4 of a decade late IMO, and won't do much to repair GM's image at this late stage.
#111
It also needs a useable trunk.
#112
...The GTO is 3/4 of a decade late IMO, and won't do much to repair GM's image at this late stage.
Even the '05 GM 5.3 truck engine gets LS6 heads...The GTO is still using LS1 heads. The LS6 is old news now that the LS2 has arrived. A slightly "detuned" LS6 should therefore be the standard engine in the GTO.
Check the fuel mileage for the GTO auto; it's awful (16/21, I believe). Something's "wrong" there, as well. Generally speaking, the car itself is wrong. Of course, it's still the quickest/fastest GTO ever built (stock vs. stock), so I suppose it could be worse. (The only "stock" one that was quicker/faster is referenced below). It was one of the more "legendary" lies in an era that was full of them:
http://www.contes.com/ccvmore.htm
"At any rate, Royal performed their famous "Royal Bobcat" treatment on the GTO, the very first GTO so equipped. The car was, in Jim Wangers' own words, "well set up." The GTO was then loaned to David E. Davis, Car & Driver Magazine's Editor- in-Chief. Wangers and Davis came up with the idea of testing the Pontiac GTO against a real Ferrari GTO (from which Pontiac had stolen the GTO name). In the resulting road test, which was published in Car & Driver's March 1964 issue, the Pontiac GTO turned the unbelievable times of 4.6 seconds 0 to 60 MPH and 13.1 seconds through the 1/4 mile. Jim Wangers was happy. John Delorean was happy. Pontiac sold tons of GTOs. The "Muscle Car" revolution was born and the rest is history!
UPDATE:
In his book "Glory Days," Jim Wangers finally admits on pages 106 & 107 that the "Car & Driver" GTO was a ringer! Wangers did have a 421 Super-duty installed prior to the roadtest!"
#114
Aluminum heads permit SLIGHTLY higher CRs; not "vastly higher" CRs as you claimed.
Now it's INTERNAL mods. Never you mind about the $10K-$20K in other mods.
#115
We've already posted 2 links showing you did.
#116
Bernoulli also describes "incompressible" flow of fluids through pipes @ sub-sonic conditions.
Ram air doesn't add HP in street applications...PERIOD. And that 10s Slomero is running 10's not 'cause of the cam, but 'cause of the thousands and thousands spend on the chassis.
#117
#118
Bzzzz, wrong. The experiments were flawed and their conclusions questionable. I've already shown how the tests were MASSIVELY flawed. You just continue to live in your little dream word.
And the tests weren't flawed.
They were measuring static airbox pressure ON THE STREET/STRIP!
This link references:
A) The Combined Gaw Law
B) The Bernoulli Equation
C) The "fact" that aluminum heads permit "vastly higher" compression ratios
P.S.
"The fluids problem shown on this slide is low speed flow through a tube with changing cross-sectional area. For a streamline along the center of the tube, the velocity will slow from station one to two. Bernoulli's equation would describe the relation between velocity, density, and pressure for this flow problem. Along a low speed airfoil, the flow is incompressible and the density remains a constant. Bernoulli's equation then reduces to a simple relation between VELOCITY and STATIC PRESSURE. :cop:
#119
:lol1: :lol1: :lol1: Yeah, and V is velocity in the Combined Gas Law, it's a cam only swap to get a slomero into the 10's, paper outflows cotton filters throughout their life, and WS6 ram air is more than domestic rice. You stupidly claim Bernoulli is responsible for ram air working LOL...the airbox isn't even designed that way. Obviously you don't understand fluids or you would realize that would require a DIVERGENT air box which the WS6 DOES NOT HAVE. YEAH RIGHT. No wonder you were duped into buying that POS plastic Slomero.
Keep dreaming. In the meantime, actually get EDUCATED in fluid mechanics before you molest more formulas.
You lied about aluminum heads not permitting more compression compared to iron. You lied about having taken fluids while claiming V is velocity in the Combined Gas Law (which you even deny after being showed 2 posts of yours to the contrary). You are full of sh!t claiming that Bernoulli's Principle is the physics behind ram air and you lied about the 10s "cam only" swap. And let's not forget you claim to be an engineer while making the retarded statement that the center of mass on a small wheels is different than on a large wheel. You even lied about ram air...first posting obvious street applications like the WS6, then changing your position to that of it working on 170MPH motorcycles and 300MPH airplanes...when obviously your point was that ram air works on STREET applications...which is ABSOLUTELY NOT TRUE and the math PROVES it.
#120
I've always stated that aluminum heads permit SLIGHTLY more STATIC compression. All other things being equal, the net change in dynamic compression is ZERO.
"Center of mass" was a misnomer and you know it. I clearly stated the correct intertia formula and any reasonably person KNOWS what I was saying.
"The fluids problem shown on this slide is low speed flow through a tube with changing cross-sectional area. For a streamline along the center of the tube, the velocity will slow from station one to two. Bernoulli's equation would describe the relation between velocity, density, and pressure for this flow problem. Along a low speed airfoil, the flow is incompressible and the density remains a constant. Bernoulli's equation then reduces to a simple relation between VELOCITY and STATIC PRESSURE."
