TL Timing Belt Question
Old Feb 4, 2008 | 08:14 AM
wahoo67's Avatar
What happens to the TL VTEC engine if the timing belt fails? I have a 04 Passat V6 and have been told it is an 'interference' engine which means that serious damage can/will happen if the TB fails. Same with TL?
Old Feb 4, 2008 | 08:19 AM
BEAR-AvHistory's Avatar
Yes
Old Feb 4, 2008 | 11:48 AM
camporealer's Avatar
A slightly more complete answer:
An "interference" engine means that if the timing belt slips, the valve can come in contact with the piston. At a minimum this will result in a bent valve. More likely it will take out the piston and the rest of the engine.
Short answer.... Very Bad.
Old Feb 4, 2008 | 01:03 PM
wahoo67's Avatar
What kind of history does the TL have regarding this rather unfortunate occurrance?
Old Feb 4, 2008 | 01:16 PM
Tripnbeats's Avatar
no history...... I dont think there are many cars nowadays that have that problem....nor will they. the correct maintenance and care of the drivetrain should result in fun times n no worries.
Old Feb 4, 2008 | 01:18 PM
01tl4tl's Avatar
There is a reason they say to change the timing belt at 7 years or 105k miles under "normal service" That leaves a safety margin
If you live where its really hot- has no ozone layer- pull a trailer- live high in the steep mountains, all those would be Severe Service and early replacement is advised.
Many members drive more miles and have gone 150k on the t-belt and then changed
Others drive very little and will change on age rather than miles. I have 80k now on an 01 so this year it will get done based on age.
IF it breaks- more than 1 valve is going to make contact and piston-rod- internal damage--well its cheaper to get an auto recycler yard (formerly junkyards) used engine, and replace the timing belt and water pump on it before install.
If in doubt- whip it out
Your wallet that is~
vaughanml2
Nov 1, 2021 10:16 AM
redsox68
Sep 16, 2015 06:18 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
