TL Tail light
Old 12-13-2008 | 02:49 AM
etodak's Avatar
9th Gear
TL Tail light
I have a 04 TL and I like the looks of the Type S tail lights, do you know if I can just do a straight swap or does it need some modification?
Old 12-13-2008 | 04:09 AM
knavinusa's Avatar
it should just be a straight swap. the size of the tail light housings are the same.
Old 12-13-2008 | 04:33 AM
erick3's Avatar
yup - straight swap: the board 'n all
Old 12-13-2008 | 10:57 AM
anarchy[sear]'s Avatar
KICKED IN THE BALLS
All you have to do is remove your back bumper. MAKE SURE YOU HAVE A SHORT SCREW DRIVER or you will have to remove your rear tires to get to some screws.
Old 12-14-2008 | 06:51 PM
CarrieLynn's Avatar
check out the depo tails...plug and play!
Old 12-14-2008 | 10:08 PM
imj0257's Avatar
Q('.')=O
yea remove bumper, remove tails, plug in new tails. done. plug n play mmm hmm.
12-07-2020 05:39 PM
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
brjones9
09-03-2015 07:30 PM
Quick Reply: TL Tail light
