TL-S headlights on '06 TL
Correct me if I'm wrong, but are these the only parts needed to install TL-S headlights on an 06 TL?
- complete 07+ wiring harness
- DRL bulb
- turn signal bulb
And how difficult is it to remove/replace the existing wiring harness? Do the bumpers, fenders, or other engine components need to be removed to access it?
Thanks in advance.
- DRL bulb
- turn signal bulb
Thanks in advance.
Why would you need the entire wiring harness?
You would just need 1157 turn signal sockets, 9005 fog light bulbs (although I would advise turning them on for extended periods of time since 07-08 headlights consume much less wattage as DRLs).
Lucky for you your ballast from your 2006 headlight will mount right up to the 07-08 headlight. (04-05 headlights have bigger ballasts).
Solder the parking, ground, and turn signal wires from your car to the 1157 turn signal sockets and put the 1157 bulb right in. You should be set to go.
And NO, you do not need to get a different bumper lol.... that is 110% wrong information.
Here is my solution to the turn signal, https://acurazine.com/forums/3g-tl-2004-2008-93/solution-1157-7443-type-s-headlights-base-814655/
No modifications to your stock harness needed.
Here is my solution to the turn signal, https://acurazine.com/forums/showthread.php?t=814655
Plus there is a self satisfaction of you doing the mod your self.
- DRL bulb
- turn signal bulb
Thanks in advance.
- DRL bulb
- turn signal bulb
Thanks in advance.
and to replace the lights at all ull have to pull ur front bumper anyway
You can't easily pop in 07/08 TL fogs into the lower grills =(
The curvature of the bumper is different etc.
A lot of custom work would be needed.
Best way for lower fogs are accord fogs.
MetalGearTypeS
Aug 29, 2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
