TL 6MT downshifiting/cornering
I working on my technique for downshifting while cornering in order to exit the corner in a lower gear and accelerate out. I need some pointers. Can anyone out there take me step-by-step through the method he uses?
Thanks.
Thanks.
Team Anthracite Member#69
Now this things assume you are a newbie at it...
The most important thing to learn first is engine rev matching. DO NOT try to learn on actual corners. Do this on the highway. Practice a couple times every time you ride. Start at 6th gear and drop one gear at a time until you get to 3rd gear matching every gear... Depending at the speed you are going you might want to try even 2nd gear... but prob not. When you master that then skip a gear... 6th-4th, 5th-3rd. You need to get to know your car really well here. Then go for the one you'll really need for most of your Mario Andriette cornering... dropping from 6th to 3rd gear... Just be careful because your engine limiter wont save you if you drop it to too low a gear.
Now this wont work on every corner but it will get you started. You'll have to take it easy at the first few corners while you get to know your cars cornering limits and then learn how much braking you should also incorporate into the equation and where to do the brakeing... This is where you'll have to learn some heel/toe techniques.
And remember no peeking at your gauges while cornering... that split second of taking your eyes of the road could be the end of your tl...
You can probably find better written instructions somewhere on the net...
I just found this one in google: http://www.318ti.org/notebook/shifting/
Hope that helps.
Hope that helps.
its not easy without heel-toe (using right foot on brake and throttle at the same time).
Best this is to work on smooth downwhifting and then try to combine that with braking.
Say your in third. To downshift smoothly press clutch, give a little bit of throttle to get your RPMs to where they should be for second gear and then release clutch (I think around 2K more). With lots of practice, and it will take a lot of practice, you can do it without thinking. You've got it down when you can't tell you're actually downshifting (meaning the car does't learch forward or backword but just maintains the same speed)
Work on that and then we can try to add braking in there as well. Then we can throw in turning.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Thanks.
Thanks.
1)hit brakes and hold clutch down
2)put car into desired exiting gear
3)make turn
4)give it a little gas to match the rom that is suppose to be at.
5)release clutch and speed off
i dun see any reason you want to be on the brakes and the gas at the same time. only a person that wants to reduce the delay of rev matching(tenths of a second) would want to keep his heel on the gas to get the rpms at the right speed immediately. you can also downshift while braking and you will find yourself in the correct exiting gear when taking the turn.
Originally Posted by dougpt10
You will want to gear into neutral after yo depress the clutch, rev match, clutch again then shift into lower gear. By using your method of just depressing the clutch and rev matching without putting into neutral and releasing the clutch you are in effect riding the clutch. You will burn it out. You really need to "double clutch" which is the technique I described![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Shift_faster
Originally Posted by cTLgo
having a 3rd foot would REALLY help :p
I'm still trying to work on my heel/toe techniques for better control starting on a hill...
Originally Posted by PoochaKannInc
I am equipped w/ a 3rd leg...
. spidey...not sure I understand why disengaging the clutch (pressed down) through a turn is dangerous. I don't do it all the time, but there are times when I do it.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
To each their own of course.
Originally Posted by prophet
herm..u should always be in gear when going in and out of a turn. Worse is when you come out of a corner and then let the clutch go, you can actually cause the car to lose control that way if you don't rev match.
Shift_faster
I agree with you about rev-matching coming out of a corner, unless you blip the throttle slightly, you can jerk/shock the driveline with some "interesting" results.
Makes sense, and I understand the reasoning. I initially thought when spidey mentioned it, it was "dangerous" because of some extreme wear to the clutch. But he explained it well...
Its a scary feeling having her buck like a freaking bronco. I'll have to tell y'all about the panic breaking I had to do while 90 MPH around a corner. yuck. Just, yuck.
Originally Posted by caball88
not sure why keeping the clutch down is dangerous, but you can also put it nuetral if you feel better that way.
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
Powered by Guinness
The 318ti notes link has a lot of good information. On a related note, another strategy is to not upshift when you don't have to. Downshifting is real simple when you don't have to do it. Think about it - you can cover a lot of range (everything legal) using second and third gear alone. Of course, I'm not suggesting driving this way all the time...
Originally Posted by Aegir
The 318ti notes link has a lot of good information. On a related note, another strategy is to not upshift when you don't have to. Downshifting is real simple when you don't have to do it. Think about it - you can cover a lot of range (everything legal) using second and third gear alone. Of course, I'm not suggesting driving this way all the time... ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
:lol2:
Shift_faster
One advantage of NEVER upshifting is you get to hear that wonderful engine note all the time. I guess the disadvantage would be 6 mpg!
Caball...I think the point Spidey was trying to make was that for "instant" acceleration in a curve you should be in a gear in case you do need to move faster or avoid something...I don't think its dangerous in any other way...
And uh Spidey...90 mph in a corner? Maybe Aegir had a point with not upshifting EVER to avoid going that fast around a curve...
I actually printed out the 318ti link to read...(yeah nothing is going to get done at work today...hmmm...just like every other day)...
And uh Spidey...90 mph in a corner? Maybe Aegir had a point with not upshifting EVER to avoid going that fast around a curve...![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
I'm just gonna shutup now before I get mauled.
:o
never stops!
People! If you are driving in NEUTRAL or with clutch disengaged (pressed down) for more than a second. You no nothing about manual driving and are stupid and should buy 5AT.
Powered by Guinness
Shift_faster
Seriously though, there are times that holding down the clutch for more than a second is fine, and in fact it helps with a smoother transition between gear changes...
never stops!
Now that I've attention,
One should not disengage from an engine drivetrain anytime. Only allowable is for the time to shift and revmatching. But when people drive in neutral or disengage clutch and glide it's very dangerous since the only control over the car would be brake at that time. To control the speed by engaging drivetrain is the best and safest control one can have.
Shift_faster
If you'll excuse me...I need a drink...all this thinking is giving me a headache...
Powered by Guinness
Moderator Alumnus
Thanks, this is useful info.
Hope that helps.
Hope that helps.
Zonian22
11-14-2015 01:20 PM
MrHeeltoe
79
10-14-2015 08:47 AM
