TL '05 fog lights help
hey im new here, but i have a tl 2005 and im trying to install foglights because i like the look. i have ordered the lights and took them to a custom shop but they said i need the mounting brackets. if so where can i find them, any help would be appreciated thanks.
Buying without doing research , tisk tisk . You already have fog lights built into your headligts. Putting fog lights in bumper , will take some custom work or doing a bumper swap to the tl that came with fogs and using the OEM fogs
OP is aware of the custom work but you are right. He should have done some research. OP all you can do (if its no the 03-05 sedan accord fogs) is get a custom bracket built, but tell us what type of fogs you got.
take it to another shop that has done custom work before .. there will not be a bracket for this unless you have one made.
there are diy on here and on youtube about installing accord fogs. and taking the bumper off is very easy.
IIRC you dont need a mounting bracket. Like project tl said there is a DIY guide (goolge installing accord fogs onto a TL) and you can use that as a guide. Um its counterintuitive that a "custom shop" cannot "custom make" a bracket or have someone tie to there business who can make one for them?
Surprised that the "custom" shop said you required brackets.
You do not need a mounting bracket.
How I mount the fogs is simple. There's a long screw that comes from the side of the bumper and straight into the fog housing that holds it.
Heck, I think I even remember someone using gorilla glue to hold them in place!
Fog lights built in the headlights isnt really fog lights to me and most members agree. The appeal of the fogs on the bottom makes the TL even more sexier.
The following 2 users liked this post by EvilVirus:
Project 04TL (03-13-2013),
THEReeM718 (03-13-2013)
^^ agreed ! Yea i dont really see how the ones in the headlights would be considered fogs , but adding them to the bumper seems like a more apropriate place for them to cut threw bad weather .
Plus like said above , looks better too
Not sure if this could count as a thread jack, sorry if it does, but maybe the OP might have this similar question once his fogs are actually installed.
For those running HIDs for fogs, did you use a relay/is it necessary?
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
