Tips for saving on gas while pumping
Old Mar 10, 2011 | 11:58 AM
SlimTL's Avatar
Lightbulb Tips for saving on gas while pumping
With gas expected to reach $5 per gallon by summer, these tips that I
received from a friend might come in handy
TIPS ON PUMPING GAS
I don't know what you guys are paying for gasoline.... but here in
California we are paying up to $3.75 to $4.10 per gallon. My line of work is
in petroleum for about 31 years now, so here are some tricks to get more of
your money's worth for every gallon:
Here at the Kinder Morgan Pipeline where I work in San Jose, CA we deliver
about 4 million gallons in a 24-hour period thru the pipeline.. One day is
diesel the next day is jet fuel, and gasoline, regular and premium grades.
We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground
temperature is still cold. Remember that all service stations have their
storage tanks buried below ground. The colder the ground the more dense the
gasoline, when it gets warmer gasoline expands, so buying in the afternoon
or in the evening....your gallon is not exactly a gallon. In the petroleum
business, the specific gravity and the temperature of the gasoline, diesel
and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the
service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast
mode If you look you will see that the trigger has three (3) stages: low,
middle, and high. You should be pumping on low mode, thereby minimizing the
vapors that are created while you are pumping. All hoses at the pump have a
vapor return. If you are pumping on the fast rate, some of the liquid that
goes to your tank becomes vapor. Those vapors are being sucked up and back
into the underground storage tank so you're getting less worth for your
money.
One of the most important tips is to fill up when your gas tank is HALF
FULL. The reason for this is the more gas you have in your tank the less air
occupying its empty space. Gasoline evaporates faster than you can imagine.
Gasoline storage tanks have an internal floating roof. This roof serves as
zero clearance between the gas and the atmosphere, so it minimizes the
evaporation. Unlike service stations, here where I work, every truck that we
load is temperature compensated so that every gallon is actually the exact
amount.
Another reminder, if there is a gasoline truck pumping into the storage
tanks when you stop to buy gas, DO NOT fill up; most likely the gasoline is
being stirred up as the gas is being delivered, and you might pick up some
of the dirt that normally settles on the bottom.
Old Mar 10, 2011 | 12:02 PM
Bearcat94's Avatar
AZ Community Team
https://acurazine.com/forums/car-talk-5/bad-mpg-tips-how-pump-gas-808160/
Jimmy_D
Oct 7, 2015 11:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
San Yasin
Sep 29, 2015 10:52 AM
