tinting tail lights
tinting tail lights
i see a lot of people paying liek $40 + shipping for those kits. whats the difference between buying those kits and buying the tint kits at walmart. cause walmarts $20 with enough tint to do 5 cars only difference is you ahve to cut it yourself. are there any benefits?
thanks
thanks
FYI, I will be posting on the black market section for a temporary tinted vinyl for the tail lamps for the Acura TL and TSX. These are pre cut for the specific vehicle and will come in 2 set. We are testing it out and so far the process has been very good. So I will keep you all posted.
These special tinted vinyl are not like those tinting film that you see on the window. It will not leave any adhesive residue onto the lamp. These vinyl are similar to the vinyl that you see on cars with roll calls. So these are temporary. If you want to take it out, just peel it off and that's it.
I will post pic in a few days!
The mylar tint film adhesive is designed for glass, it will not adhere to plastic very well. It also does not stretch. You need to have an adhesive that sticks immediately so that you can stretch the vinyl material to fit the compound curves of the lens. I would be afraid of the temporary material coming loose at speed as well as during washings. I have been using a signage vinyl that works perfectly for this application. It can be removed if necessary without any residue, it is intended to last for 7 years on exterior signs. It is easily stretchable at compound curves and readily shrinks if needed with heat.
can u take it off and re-apply the same piece over and over again? cause that will be good for when u get tickets, then u just rip it off and get the ticket voided and throw it back on. keep me posted im interested
.:KCCO:.
Originally Posted by pohljm
The mylar tint film adhesive is designed for glass, it will not adhere to plastic very well. It also does not stretch. You need to have an adhesive that sticks immediately so that you can stretch the vinyl material to fit the compound curves of the lens. I would be afraid of the temporary material coming loose at speed as well as during washings. I have been using a signage vinyl that works perfectly for this application. It can be removed if necessary without any residue, it is intended to last for 7 years on exterior signs. It is easily stretchable at compound curves and readily shrinks if needed with heat. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
and how much was it?
I deleted a post in this thread and tried to send the poster a PM but his mailbox is full. If he will send me a PM I will explain why the post was deleted.
The vinyl material I am talking about cannot be removed and then reapplied, the material will stretch out when you pull it off and will not look good when reapplied although it will still be sticky enough. Also it wont leave a residue. You can get it from a commercial signage supply store. its used for diecut signage
Originally Posted by ayethetiense
if that post that was deleted was a response to my question, please pm me. thanks
Try this link. I purchased both front and rear from this vendor. Worked like a charm, on and off whenever you want. Watch out for car washes and high pressure hoses. Will not come off at speed (up to 110+ anyway…) or when raining.
http://cgi.ebay.com/ebaymotors/ACURA...44549243QQrdZ1
Tinting tail lights
Stickercity.com has a complete set of tints and protective film for front and rear lights. They work as advertise and will not peel if installed using the supplied instructions. http://www.stickercity.com/store/pro...at=1451&page=1
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
