Timing Belt Question
Old Apr 9, 2013 | 10:19 AM
Rob1704's Avatar
I bought my 05 TL without any mechanical history or records and am a little concerned because I don't know if the timing belt has been replaced. Is there a way to visually inspect and determine age estimate w/o taking it to a garage?
Old Apr 9, 2013 | 06:27 PM
nttstt444's Avatar
You really should have asked about that before buying it, as its a major service but usually the belt itself dosent show much sign of wear at all. Its tough to tell really. I just had mine done today at 103k, my old tb looked nearly new to me. Maybe if you know of the dealership or shop it was serviced at give them a call?
Old Apr 9, 2013 | 09:41 PM
truonghthe's Avatar
no way you can tell without taking the timing belt cover off which require you remove drive belt also. Why you didn't ask for the carfax and see the history prior to purchase?
Old Apr 9, 2013 | 10:08 PM
Pat04TL's Avatar
Rob, how many miles are on the car?
Old Apr 10, 2013 | 12:41 AM
Acura98's Avatar
5th Gear
I'm in the same situation. Mine has half service records but nothing about a timing belt or anything in the last few years for that matter.
I did this. What am I looking for. The belt looked new to me.
Old Apr 10, 2013 | 06:43 AM
truonghthe's Avatar
^^^ you are looking for crack, flexibility for age belt, if not then it probably is a new belt.. I would spend $35 for the carfax record to see if it had been done. BTW you can also check the crank pulley bolt to see if there is any metal shave (rounded kinda like almost strip a little of metal off) around it since it need 450 ft/lb or more to remove that bolt. If the bolt look complete then the TB haven't been done.
Old Apr 10, 2013 | 08:32 AM
Tehvine's Avatar
6spd FTW
You can also see if one of the battery tie down bolts/studs has been ground down to a tapered edge.
Old Apr 10, 2013 | 03:45 PM
Adobeman's Avatar
The DVD-A Script Guy
Looking at the crank pulley bolt is not definitive. There's not necessarily going to be anything noticeable. Especially after some time.
Carfax ? Again, not necessarily going to say anything if some indie or owner did the work. Worth a shot I guess if it's cheap enough.
If you see cracks then it's got to go but if even if it looks new that doesn't really mean anything either.
So in the end if you can't find out for sure then you are going to have to make up your own mind. There's ample threads here with much passion about when to do a TB so please don't stir that pot again here
Assuming a dealer did it to the shop manual spec and didn't use a different bolt/tool to do it. My guess is the dealer mechanics don't remove battery tie downs off each car but have a spare one (or equivalent) in their tool box.
Old Apr 10, 2013 | 09:07 PM
crbnfbr's Avatar
My TL came with a tapered battery hold down, and according to my 04 service manual they all come that way.
Old Apr 26, 2013 | 02:37 PM
Rob1704's Avatar
Originally Posted by pat04tl
rob, how many miles are on the car?
95k
Old Apr 26, 2013 | 02:49 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
^^assuming this was a recent purchase for you. i'm willing to bet that the TB was NOT done by the previous owner at that mileage.
Old Apr 26, 2013 | 03:29 PM
ez12a's Avatar
the overexplainer
i'm with Trigirl. Most people dump their TLs it seems before this "major" service. Chances are it was not done if one buys or sells a car around this mileage.
Old Apr 26, 2013 | 09:53 PM
joelmatt89's Avatar
Yeah I would be shocked if any previous owner who wasn't on here did it before 105k. Most people just wait for the service reminder. Honestly if your gonna take your cover off and go to the trouble of checking you mine as well just change the belt. I really doubt you could tell for sure anyways if it was done. Its really not all that hard you just have to make sure you mark it really well so you know you get the new one aligned correctly.
Old May 6, 2013 | 07:13 PM
Rob1704's Avatar
Do you know at what millage the reminder pops up?
Old May 6, 2013 | 07:19 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
^^give or take a few thousand miles of 105k.
Old May 6, 2013 | 08:00 PM
Rob1704's Avatar
Thanks.
Old May 6, 2013 | 09:23 PM
Kevy604's Avatar
4th Gear
so 105k miles = 168K km,the timing belts are good for that long?
vaughanml2
Nov 1, 2021 10:16 AM
redsox68
Sep 16, 2015 06:18 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
