for those who have zkw's
did you make the spacer for it?
I didnt know you can buy TRUE ZKW's from retrofitsource. I thought all they had were the ZKW-R's. I am curious as well because I was looking to get some ZKW's (probably the replicas since they are soo cheap). And I wanna make sure they are in correctly.
When I had my 07 base TL I installed ZKW-R's I believe they DID have a small notch and I installed the notches at 6o'clock position. If that was the right way to do it I dont know.
James
James
Paging JnC... Paging JnC...
The real ZKW's need a 3mm spacer so the beam is properly focused. Search and you will find a thread on it here...
To go along more with what I was saying above. When I installed the ZKW-R's on my 07 base the cutoff didnt get any sharper than stock however it did add a bit of color. I was slightly dissappointed though because for some reason ever since installing them the left beam had a noticeable yellow spot in it. Never did figure out why. I ended up trading the car and now im looking to add some clear lenses to my 07 TL-S.
James
James
k i installed them, no spacer they were already to tight put the notch at 6 oclock. now my question is why are my cutoffs not meeting anymore?
![](http://i96.photobucket.com/albums/l168/h2point2/IMG00018.jpg)
hopefully i do not have to remove the damn things again, although it was not to hard.
where do you get the spacer and how is it installed if i need it. the lines are crisp i love these lenses. zkw-r's
Former Sponsor
The notch that you have in the ZKW-R is not the same as the real ZKWs. In your case you still can better the beam by slightly bending the cut off shield, spacing the lens or doing both.
no i didnt mean i got true zkws from retro i meant the zkw needed a spacer and i had the retros and never used a spacer. I also would like to know about bending the shield and if i can do this without taking the headlight apart again or just take the projector out????
James
mrkingstonvi
02-22-2016 01:53 PM
