for those w/moleskin installed for tint
Old May 25, 2007 | 05:42 PM
jetblakTL's Avatar
The Darker the berry....
Has anyone had problems with the moleskin streaking the windows after the car has been washed or after it has rained? I have a friend with an 05 TL who says he can't roll down his windows for hours after he washes the car because the moleskin gets wet and streaks his windows. I don't know what brand of moleskin he got installed but he says it is pretty bad. I haven't seen many complaints about this on this board but I figured I'd ask anyway.
Old May 25, 2007 | 07:44 PM
Ron A's Avatar
Administrator
How can it get wet unless he washes his car with the window open. The moleskin is on the inside and if the window is closed it shouldn't get wet.
Or did they install the moleskin on the outside?
Old May 25, 2007 | 08:47 PM
TL1999's Avatar
GO DAWGS!! SICK'EM!!
on the outside where that is happen to me...
Old May 25, 2007 | 09:32 PM
Ron A's Avatar
Administrator
They are not supposed to put moleskin on the outside! If they did then they should remove it, and if they didn't, then something else is causing the streaking.
Old May 26, 2007 | 04:48 AM
EXACCORD's Avatar
Just had a problem with my moleskin on my drivers side window. It came of and all of the adhesive was all over my window. Took me a LONG time to clean it up. So far only window that had a problem and have not bothered to even replace it. It did seem like water was a problem and I have NO IDEA how it happened but that was the case.
Old May 26, 2007 | 06:19 AM
Indy Paul's Avatar
I was thinking the same thing. If it's on the inside and it's getting wet, then he has other problems that need to be fixed 1st, because water is getting inside the door! If they installed it on the outside, they screwed up and it should be removed. I installed it myself and have not had any problems thus far.
Soul_Deamon
Nov 13, 2018 04:44 PM
TLDude876
Dec 28, 2016 03:18 PM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
asahrts
Sep 4, 2015 05:55 PM
