For those with camel / parchment interior....
Looks great.
I've got the Parchment interior, but sometimes I wonder if I should've gotten the ebony. The carpet mod goes a long way toward making the interior darker.
You said it took awhile to do it. Does that mean an hour or two? Or six?
What is involved? Do you need to take out the seats? Any tools needed to un-hook the old carpeting? Can you put back the old-carpet, or does it get damaged when it gets removed?
Thanks for any info.
Originally Posted by datmrman
special-ed, I think it looks good with dark colored cars like yours. Don't think it will be the same in my WDP though.
Originally Posted by evantec
Looks great.
All of the seats need to be taken out as well as the plastic liners around the door wells and bottom part of driver's side dash and glove box. Also the whole center console and panels as well.
You can put back the old carpet back but once you replace it, I doubt you'll want to spend the time to take everything out again especially since you'll be having to unbolt the front seat belts and front seats so you increase the likelihood of stripping the threads for those mounting points especially if you don't take your time when putting everything back together.
Originally Posted by special-ed
If you're working solo, I'd say probably a good 5-6 hours max (at least 3.5-4 hours min) depending on how much of a rush job you do trying to pull off the trim pieces without snapping all of your tabs off. On top of that, you'll need to get under the seats and disconnect some harnesses, unclip a few harnesses around the shifter area. The gas pedal was a bitch to get off for some reason.....oh yeah, I remember the manual said to push the lever toward you when you actually had to press the lever really far down to unlatch the gas pedal.
It sounds like a bigger job than I might do, thought it still looks worth the time and $$. I also picture myself with the seats pulled out trying to figure out how to get them back, thinking I just ruined a $30K car and I can't even drive it back to the dealer!
One last question -- When you said the manual said to push the lever toward you were you working from a service manual? That probably helps a lot telling where all the connections are. Not that it makes it easier to undo bolts, cotter pins or tabs which break!
Thanks for the info.
The manual definitely helps especially since your dealing with wiring harnesses that deal with the SRS of the driver and passenger seats. Also, you'll need to un-hook 2 main harnesses that run along each side of the shifter assembly so you can properly lift the shifter assembly up without putting any strain on those harnesses and pull out the carpet from underneath. You'll also have to disconnect 1 of the harnesses from the SRS module that lies beneath the console compartment trays and the antenna cable also.
There were a couple of spots where I used a pair of Tin Snips (heavy duty metal cutter) to cut the old carpet in 2 places to make removal of the old carpet alot easier. 1 area by the shifter and the other by the gas pedal so I could properly see, understand the mechanics, and get to that little lever that unlatches the pedal from the floor board.
I'll get these daytime pics posted in a sec.
I want to do this...
I'm onlty struggling with the investment, or lack there of.
I'll the mods I've done so far, I can remove and sell on the forums (for a nominal loss), if I return the car to stock to sell/trade.
You'll never be able to sell these parts, they HAVE to go with the car. Al the parts I want to change out (pretty much the intire lower interior changed to black, with tan seats and headliner) is near $800.
I've tried to aquire these parts 2X from junkyards, and all you get is busted crap, so you have to buy new. Just not sure I'm ready to throw $800 away to make me feel better about not holding out for a WDP/Ebony.
Maybe at bonus time in March.
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Maybe not for everyone but he did a hell of a job........... rest assured special-ed you now have a one of a kind TL!
Personally I think it looks great.
Good or bad, thanks for the comments guys. At least you can see the options now.
For me personally, this car will definitely become the official daily beater in about 1.5-2 years but right now, I need a clean looking interior when I'm taking clients out to lunch, etc (which is frequently) and I don't want to have to spend the extra time that it takes to keep a light colored carpet clean all the time. On top of that, gotta deal with the little shorty who no matter what, always seems to track dirt in the car.
So right now, this fits the bill and I actually really like it especially knowing that the 2-tone TL-S's are setup very similarly which suits my personal style because I like things more on the sportier side.
1. How much did the carpet run you?
2. Where did you buy the carpet?
3. Does the carpet come ready to install?
I would love to do this change... Maybe I can get Kennedy on board and we can both get it done...
call me zimma!
From: I am from NH but currently live in RI when at school
I really like that look... ties in great with the black part of the dash.
I am also interested in how much it ran you, and how easy it was to take the interior out and put it back in, aside from the time it took.
Thanks guys
BTW, went to go check out some of the new Benz's that were being shown for this SAP Tennis Tournament that was out here in San Jose. One of the coupe's (can't remember the model) had the same 2-tone setup which I distinctly remember because it was just under a $100k sticker on the window.
Kaa - Ching !!!
Looking back on this thread today - I just took my all season mats out for the summer and replaced them with the charcoal carpet mats. Next thing you know I was envisioning the entire carpet charcoal - I have a quartz interior and the charcoal carpet would look so so so good !!!! The light gray is already dirty in a few spots and it should have been charcoal to begin with......
I wish I had the balls to rip out the interior............
I was looking at the 2012 (2013?) models in the Acura showroom. I think I saw a TSX with a two-tone parchment seats with rich dark brown carpets. Really nice combo. What do ya'll think? Was I seeing things. They weren't black or greyish black. I'm sure they were dark brown. Really sharp looking.
However, the upper dash of my 06 has a black/charcoal hue and would tie in with black carpet.
Decisions decisions.
