tap into turn signals
UA6mt NBP
i want to run my leds into my turn signals so they blink when turn signal is kicked in, couldnt find a write up on it. Seeing which wires are used to do what?
I was trying to get him to provide more details.
if he needs his turn signals to flash accordingly, we have switch back LEDs that flash amber but are white(or what ever color he chooses) when not flashing.
you can attain these switchback leds from VLEDS.
for example....
for example....
![](http://www.ijdmtoy.com/ebay/SMD_LED/Dual_Color/switch-back-LED.gif)
BANNED
yeah justnspace, duh.
OP, we need more info about what you are trying to do.
UA6mt NBP
i have an led strip im going to put in the headlamp housing and i want them to run them off of my corner lights as well as have them work with the turn signals
BANNED
so you've got an led strip that you're putting in your headlights. you want to splice them into the parking light supply AND also have them blink when you apply the turn signal?
do i have that right? and if so, may i ask why you want to do it this way?
UA6mt NBP
you are correct, that is what i want to do and i think it will look good and if not then i will remove it, its worth a try
RAR
I would suggest looking for the threads on making the side markers blink with the turn signal. If you connect LED's to the turn signal line, I'm pretty sure you will need a load resistor to absorb the excess wattage.
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
