TAKE A LOOK !!!! I RUINED my TL !!!
B A N N E D
I attempted on clearing my headlights out ... i ran into 2 problems at the end I was wondering if someone could please help me, because i followed the DIY on this website...
1. right headlight won't fit correctly, (could have the oven made it bend somehow and have cause this ? ) as you can see, notice the huge gap and silicone... Im in the search for a new one, but hopefully someone can save me from the gap and fog.
2. i have an aspec kit, and at the end of the install, i had to brackets that i believe go on the side of the bumper but im not sure where?
[IMG][/IMG]
..........i know i sound really new to this, and its true because i am, the only think i've done to my car, is exhaust, short shifter, aspec underbody kit, rims....so basically nothing dealing with headlights and the OVEN !!!
[IMG][/IMG]
One on the right for me
did you push the lens all the way back into the base? I had to bake the headlight againt to get the lens to fit as tight as it did stock. I've done this twice and have had to do that both times. I imagine that if i didn't, the headlight would stick out like yours did.
Is that "fog" a heat burn from the oven?
.:KCCO:.
first of all, is that fog or is that melted plastic?
second, did you install the base of the headlight properly? is the base and the front cover put together correctly as well? make sure there are no gaps when you squeeze both parts together.
Which DIY did you use, there are several of them, some not as clear as others. I hope mine was clear.
B A N N E D
that is fog, i read that using a blow dryer will make it go away, will this really work ?
B A N N E D
thank you soo much !!! you saved me a right headlight thanks !!!
B A N N E D
i think imma get some clamps, as advised by a member.... because when i siliconed it .. but you think ill have a problem with the aftermarket silicone... being able to melt again...
B A N N E D
Originally Posted by MichiganRich
Nice mod, that is a big improvement over stock.
haha you funny... itd be nice if there wasnt a big gap and fog...
acura-cl.com OG
make sure they are sealed correctly or it will look like a high humidity greenhouse in those headlamps and you will end up taking them out again to re-seal. like subinf said, make sure your lense are slid into the grooves correctly and re-heat them to make a good seal.
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Let us know how you end up here .......... sorry you had to go through this. I like the clear look too but wayyyy too afraid to DIY.
B A N N E D
man i felt just as you did, but after running out of things to do to my TL.. i needed to give this a shot...i regret it soo far, but hopefully all the helpful tips from experienced members, will force me to change my mind..
B A N N E D
so you're saying the "fog" will go away if i just simply heat again and reseal?...wouldn't i need to open up the whole thing and wipe away the fog at least?
B A N N E D
I wish you the best buddy - when it's done it looks hot!! If worse comes to worse you can always get a new headlight no ?
yea you're totally right, its not like the car is messed up as "acidhorse" was trying to imply... the car run greats and the interior is next to perfect... just the headlights need some fixing
If it's already fogged up... you might have to take it apart again or... if you have a number of dry days and the existing fog goes away... then resealing could work.
Bottom line is that plastic is very unforgiving stuff, especially when it's designed and built to be assembled only once, never to be taken apart. The more times you pry it open... the worse it gets.
If it were me... I'd take my lumps and buy a new set.
Have fun with your car and learn from your mistakes.
gurney
Be kind to us truckers !
Originally Posted by gurneyeagle
You've got guts to even attempt doing this. If I tried anything like this, it would be a disaster.
gurney
gurney
I had just about the same amount of guts, or should I say confidence, 29 years ago (30 in your case).
edlinnguyen...
God hates a coward... you'll get it squared away.
B A N N E D
Originally Posted by FLBusa
No... He's saying that if it's not sealed "air tight" it will fog up.
thanks man, i've been trying that lately...i put tape around it but its been so dang cold so i think the fog will take longer to go away...but yea imma try this sunday to fiz that whole headlight..using clamps and maybe even taking it apart...and maybe try the blowdryer or somthing to fix that fog... thanks for clearing it up though
B A N N E D
gurney
gurney
thanks man but it looks like its going to cost me at least 75 bucks to replace the left side and if i can't fix the right (the fogging and the gap) then its going to be another 75-100..not mentioning some silicone and spray paint (25-35 bucks)....
so it was an expensive mistake but hopefully it will help someone to avoid this
B A N N E D
Originally Posted by 007TL-S
if worse comes to worse , just get you some new headlights!, spend a few buck's and leave the install to the pro's and save yourself the aggrevation and headaches!
B A N N E D
Good advice ^
edlinnguyen...
edlinnguyen...
thanks man thats some really inspirational words... i really mean that.... thanks and i'll tackle this ..on sunday (probably take me the whole day... no rushing the this time around !!! thanks thought man !! i have no choice but fix it ...i'm not going to drive around like that...discrace to all TL's !!!
The first time I re-installed my headlights, I had a gap just like yours. My problem was that I didn't bolt it on correctly. What I did was bolt the two top screws really tight, which pulled it up, then that caused it to get miss aligned. So I just loosened them, bolted in my other bolts and evenly I began to screw them in.
IF your problem is just lining it up, just play with it. If your housing is bent, well then its bent. It should be fine if you didn't bake over 225 degrees. I've baked my headlights twice and they didn't bent, melt, or anything. And like what others have stated, make sure the lens is fully intact, and the clips are cliped in.
B A N N E D
a gap just like mine !?!?!?! oh man am i glad to hear that you fixed it then !!!... man imma try this on sunday thanks !!! you saved me a good 100 bucks..thanks.. !!!
really ? i thought some members mentioned that a lot of places if any would even attempt this on a 05 tl... but if i can find a shop in the seattle area then i'll do it if its not too expensive...because i think if i give this one more shot i'll be fine..i was just distracted and in a rush the first time an expensive mistake...but its ok
Have to give you credit for making a run at this mod...live and learn
B A N N E D
Originally Posted by ChicoOG
I checked every shop in my town, not one would attempt this...too much liability if it didn't work. I came across JnC on this board and he color matched a pair for me, in addition to adding ZKW lenses. They look real sweat, I'm having them installed (professionally) next Weds. The labor was $250 and I have to send him my headlights once the new ones are installed.
tell me how it goes... im doing mine this sunday...by the nonprofessional himself, ME !!!
Dude, your fine.. at least your HIDs would still work. Now even though my headlights came out okay from the clearing process, if I were to see one of my HIDs blow out.. then I'd call it a failed project.
B A N N E D
B A N N E D
Originally Posted by enigmaos
please keep us posted.
B A N N E D
thanks for the gay wave :gheylaugh:
can't wait to see the finished product.
didn't you say you gets urs clacked out also...got any pics
B A N N E D
Originally Posted by Final
Cant wait till you need help on the forums...
is this a good thing or a bad...couldn't tell by your tone ?
B A N N E D
here ya go (gloss black):
enigmaos, what kinda turn signal bulbs do you have in there? I have 12 LED turn signals, but getting annoyed of the fast blink rate it creates, and too lazy to install a resistor
