Tail light replacement
Just discovered I got a cracked rear tailight. I'm suspecting some neighborhood thugs are the ones to blame.
I'm planning to replace it myself. Where would be a good reputable source of getting TLS tailights and if you've replaced it [yourself], how easy was the process?
You can follow these DIY's to get an idea of how it's done:
The following is a step by step DIY from a fellow AcuraZiner:
https://acurazine.com/forums/3g-tl-2004-2008-93/taillight-cover-replacement-3g-garage-e-094-a-588378/
The following shows the service manual scans on how to remove the bumper and the tail light:
https://acurazine.com/forums/3g-tl-2004-2008-93/how-do-i-remove-rear-bumper-569062/
Here is a video of the bumper removal:
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-video-removing-your-rear-bumper-3g-garage-e-095-a-619706/
All of these and more DIY's are available in the 3G garage, which is located here:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Check it out.
The following 3 users liked this post by Kikirra:
Awesome. So from reading it, you can acutally just replace the lens and not the whole taillight unit? Because my damage is only on the lens, bulbs and everything are intact.
Correct. If your LED's (tail light/brake light) are still working, you will be able to re-use them. You'll have to take the LED board off the old housing and put it on the new housing. Make sure you remember to re-use all the foam gaskets on the new housing.
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
