Switchback Questions
So I did a search and read up on switchbacks but there was couple questions I need answered. First off all did they fix the issue with the switchbacks needing to warm up first before they actually work? I know this was a problem initially on the new 3/4" 30 LED SMT Tower. Has anyone tried the 48 LED SMT Tower? Does it have the same issues?
One or Two?
I have the 60 LED SMT switchbacks from v-leds and they work fine, no warm up necessary, direct fit, just plug and play. You do still need to install load resistors if you don't want the hyper-blinking to occur.
you need these for your 04
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
48 m-smt size: 7443 (perfect fit)
6ohm resistors (if you don't want hyper flashing turn signals, do a search for resistor installation)
So far no problems with mine, I didn't use the turn signal immediately after install though, left it running for about 15 min to play it safe
whats the best color hid to get for the superwhite led turnsignals... freaking stock hid bulb doesnt cut it looks off... im thinkin either 6k or 8k.. i prefer 8k what do u guys think
Chapter Leader (NY/NJ)
i just got mine today from V-leds and the only 7443 they have are 48led. ABP_04tl suggested gettign the 30's cuz of the difference in boards but only Autolum. has them and as i hold Rocky as the LED Guru i opted to never buy from autoluminate. they do have 60 led switchbacks but not 7443 according the the V-leds website.
V-LEDS TYPE 2 DUAL COLOR CHANGING 60 M-SMT TURN SIGNAL
http://www.youtube.com/watch?v=aLDmlT12UUA
King of NYC
So other models come in 60LED, wow that's crazy. The lights look like DRLs on that Toyota truck!
Hmm why is there a delay between the 2 cycles? I have the older 20LED model and it works directly without a delay. I wouldn't have replaced them unless they started to slowly burn out. I haven't installed my 48LED ones yet but I wonder if it operates like that video. I hope not. I hear many people say there is a delay with the signaling cycle. Is everyone experiencing that?
Has anyone installed the "LED protectors" to help protect against surges? Has anyone experienced a failure after using them? I bought them and I wonder if they will help?
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
04, 60, acura, autoluminate, install, led, resistors, rip, signal, smt, switchback, switchbacks, tl, tower, turn
