Swapping the plus & minus..............
I'm thinking of swapping the wires/plugs on the console of the automatic for the plus and minus. I want plus (upshift) to occur when I pull back on the shifter and minus (downshift) when I push the lever forward. I have a BMW M3 with SMG transmission, and that's how it works. I really don't care if the "+" and "-" on the console are wrong, as I never look at that anyway.
So can it be done easily, and will it reverse the paddles (which I don't want...I like the paddles exactly as they are).
It seems like I should be able to just swap the plugs....assuming there is enough wire to reach.
Advice?...Hints?....Will it work?
This is on an '07 TL-S with automatic
Registered TL Lover
i tiried but all i found was this but someone posts in here that is all that you do
https://acurazine.com/forums/showthr...hlight=shifter
xsilverhawkx
09-28-2015 06:51 PM
