Supercharger or Turbo????
Old Jun 24, 2004 | 10:44 PM
ravingstylez's Avatar
Hey ,
Just wodnerign what do u think i should do guys custom turbo kit that wuld run me 4500$ that i think wuld mostlikely void my warantees or the comptech that wuld keep my waranttes htat would run me 6000$.... im in a dileema ..............turbo more horses and can do more fun stuff with one .. or supercharger that makes ure car faster just not as fast as a turbo would???
Old Jun 24, 2004 | 10:48 PM
1SICKLEX's Avatar
http://www.caranddriver.com/article...5&page_number=1
The Steering Column
Slowly but surely, horsepower is killing front drive.
BY CSABA CSERE
July 2004
There seems to be considerable trepidation in some Detroit circles about the switch from front- to rear-wheel drive in cars such as the Chrysler 300, Dodge Magnum (replacing the Intrepid), and Cadillac STS. And if we believe our spies, most future big sedans from the Big Three will propel themselves via their rear wheels.
Some critics view this switch as little more than a fashion statement, much like raising or dropping the hemline of a woman’s skirt, and designed to juice sales by giving advertisers something to talk about. Others don’t want to lose front-wheel drive’s traction advantages in winter and fret about fishtailing down snowy city streets with a rear-driver. Some even worry about losing the slightly lighter weight and more efficient packaging available with front drive.
Given the enormous expense of replacing a front-drive car with a rear-drive one, no car company would do it just to provide the marketers with a new talking point. On the other hand, a discussion of front drive versus rear drive in slippery conditions is more relevant. There’s little question that by placing between 60 and 65 percent of a vehicle’s weight over its driving wheels, front drive develops more traction than does rear drive—unless the rear-drive car happens to be a Porsche 911. The only thing better is four-wheel drive, which puts 100 percent of a vehicle’s weight on its driving wheels.
Adding traction control into the equation doesn’t alter this traction pecking order. However, traction control does ensure that a vehicle makes the most of its available grip and helps a clumsy driver from losing control because of wheelspin.
Remember, though, that the definition of traction is grip that allows acceleration. Grip for cornering and braking is completely different, and there’s no evidence that front drive provides any advantage in these areas during winter driving. Electronic stability-control systems make the most of the available grip regardless of which wheels are driven, but if you really want secure winter handling, you need to change to snow tires. Four snow tires will improve traction as well as braking and cornering grip to the point where the winter merits of front and rear drive are rendered irrelevant.
Once we get away from the slippery stuff, rear drive has traditionally displayed better handling because it splits the duties of steering, cornering, acceleration, and braking more equitably among the four tires.
During acceleration, for example, although front drive provides more traction the instant you press the throttle, that advantage diminishes as soon as the car begins to accelerate. This action is caused by the inertia of the car’s center of gravity that is about a foot and a half above the pavement. Commonly called “weight transfer,” this effect on an Acura TSX, which has about 60 percent of its weight on its front wheels when standing still, shifts more than 300 pounds from its front to its rear wheels under hard acceleration in first gear.
The BMW 325i, similar to the TSX in size and performance, has a nearly 50/50 weight split. When accelerating, it undergoes a similar front-to-rear load transfer. But whereas traction in the TSX decreases about 20 percent under hard acceleration, in the 325, it increases by a similar amount.
Under braking, a similar load shift occurs, only this time it’s from the rear tires toward the fronts. With a front-drive car, this means that during maximum braking the front tires might be doing more than 80 percent of the stopping. A more even distribution of braking force would be beneficial, which is why rear-heavy cars such as Porsche 911s always stop very well. Obviously, the forward weight bias of front-drive cars is not helpful.
Nor does it help in cornering, where an equal weight distribution works best. In fact, since so much cornering takes place in combination with some acceleration, a rearward weight bias is advantageous, particularly when combined with larger rear tires. A mid-engine layout provides this configuration, which is why it is chosen by all race-car builders when the rules permit.
Okay, most of us are not exploring limit handling on the street, but we’re all familiar with the many ways that applying power can corrupt the steering feel of front-drive cars. Torque steer is the classic problem, causing the steering wheel to twitch in your hands while the car pulls in one direction or the other when you press on the gas. Equal-length half-shafts going to the front wheels have largely eliminated this problem, but others remain.
During hard acceleration in the lower gears, front-drive cars often lose some directional stability and are easily deflected by bumps, dips, and crowns in the pavement. Rear-drive cars can fishtail when they lose traction, but front-drivers often “fishhead” under the same circumstances.
In corners, particularly slow ones, many front-drive cars lose self-centering under power. The driver can’t easily tell whether this is a front-drive effect or an impending loss of grip. In some cars, such as the Dodge SRT-4, you can let go of the wheel completely in midcorner under power and the steering wheel doesn’t move a degree. And when a limited-slip differential is employed in a front-driver, these effects are sometimes amplified as the diff decides which wheel to favor with power.
Despite these flaws, we’ve found many front-drive cars over the years with terrific handling. But this was years ago, when power was more scarce than it is today.
The first VW GTI sold in America—back in 1983—had all of 90 horsepower and needed 9.7 seconds to get to 60 mph. When Chevrolet introduced its front-drive Celebrity mid-size sedan in 1982, its most powerful engine was a 2.8-liter V-6 with 112 horsepower. That Celebrity replaced the rear-drive Malibu with a standard 3.8-liter V-6 making 110 horsepower. With only a piddling 112 horses, it didn’t matter which end of the Chevy was driven.
But today, Honda Accords and Nissan Altimas come with 240-hp V-6s, and 300-hp luxury sedans are everywhere. At these power levels, front-drive has reached the limit of its competence.
I don’t even want to think about driving a 340-hp Chrysler 300C Hemi V-8 delivering power through its front wheels. In the end, you can have either front drive or plenty of power. But you can’t have both.
Old Jun 25, 2004 | 12:01 AM
Aegir's Avatar
Powered by Guinness
There are a lot of satisfied CT supercharged 2nd gen TL and CL owners out there. I think you'd probably enjoy the SC more in daily driving with fewer headaches. Beware of hidden costs on a custom TC install like programming and tuning.
Slow98teg
30
Jan 2, 2017 09:01 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
81brettkeith
Sep 15, 2015 06:04 PM
