Stupid map light
Old Jun 27, 2006 | 07:54 PM
GICHOE's Avatar
Stupid map light
When you tried to replace the front map lights, did you guys have to take the entire homelink panel off too or can the clear plastic covering just pop right off like the rear dome lights can.
thanks
Old Jun 27, 2006 | 07:57 PM
LKLD's Avatar
I've been Canonized ;)
Just pop the clears off. Now the bulbs themselves...well, that's another thread.
Old Jun 27, 2006 | 08:35 PM
GICHOE's Avatar
The bulbs should come out without a problem right? It's not soldered in or anything?
Old Jun 27, 2006 | 08:40 PM
Tonywp75's Avatar
Dont Touch My Car !!!
nope, u can use a needle nose plier to take out the bulb, which is much easier. You can also try it with ur finger or soething else. Its easy.
Old Jun 27, 2006 | 08:53 PM
dmarcus48's Avatar
one idea i've seen on the forum is to use rubber gloves. I took the reflectors out before i knew this. or loop something around the bulb so you can grab it.
Old Jun 28, 2006 | 05:16 PM
A SiQ TL's Avatar
Another idea I saw here was to use about six inches of electrical tape, fold it lengthwise, wrap the middle around the bulb, hold on to the ends and pull. I used this method to replace mine and it worked quickly and easily.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
