Stumped Rear backseat removal ggggrrrr
Grrrrr Im stumped... Im attempting to install my new factory subwoofer but Im at a standstill. I removed the rear back seat bottom which was the easy part I unbolted the 2 bolts that were holding the back bottom half and the 2 bolts that are holding the seat back... Now this is where I became stumped I understand there are 2 clips holding the seatback in place but for the life of me I can not see these when I lift the bottom half straight toward the ceiling... Does it matter that Im laying on my back while I lift the seat back to the ceiling? Am I not lifting it high enough? When I do lift it its not going to the ceiling simply because it feels like theres alot of tension and I dont wanna break anything.
Where are these 2 clips? I searched and I referred to one thread in particular on the forum but I dont see the clips in which he points out in his thread.
Standstills suck only thing worse is moving like syrup! Advice needed fellas.
05 AM TL
clips? do you mean bolts? after removing the bottom part, there are 3 bolts to take off at the bottom, remove the headrests, remove the bolts hidden behind on each side, move the seatbelts away, lift then pull the back seat.
See dude thats what I thought I was trying to get a ratchet with a extension back there and almost had it but wasnt sure if I was turning the bolt because its so goddamn hard to see its like no room it just seems so not right. So its a 10mm ok kool
SSM FTW
It's a bitch removing the rear seat if you don't loosen those hidden bolts behind the headrest. When I installed my coilovers, I search for a DIY on acurazine. Everyone said there were three bolts but no one specified where they were located. So I figured it should be a no brainer. 45 minutes into it I decided to google it and finally someone from another website had detailed pictures of the process. Now the frame behind my seat where the bolt goes are all bent up LoL bit you can't tell with the seat on.
Let me know if you can't find it. I'll take pictures or make a video because I see members posting all the time about this.
Registered 3.5L Member
These took me FOREVER to find when I was doing my coilover install I know exactly what you mean OP...It was driving me INSANE!!! Luckily member murph145 answered his phone when I called him for advice
AZ Community Team
Received 7,771 Likes
Pics and Sevice Manual Scans here:
F-070: DIY: How to remove the back seats to put the suspension?
https://acurazine.com/forums/showthread.php?t=107568
From the DIY/FAQ page here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Fearless DIY Guy
Bearcat, my suspension install DIY is not in the garage, it's fully detailed there
OP, HERE YA GO https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/diy-ht-spec-coilver-install-dummies-any-other-suspension-3g-garage-d-091-a-816065/
PWNage133 (04-19-2013)
AZ Community Team
OP, HERE YA GO https://acurazine.com/forums/showthread.php?t=816065
It's in there. D-091. Your thread title was changed too.
Honest. Check the edit date:
12:54, 17th Apr 2011 Bearcat94 Thread title (original 'DIY: HT-Spec Coilver Install for Dummies! (or any other suspension!)') changed
DeathMetal (09-30-2011)
Thanks fellas... why couldnt I find this earlier! Wasnt a complete waste of $40 but dammit I felt so defeated I couldnt find these two bolts near the headrest I actually took out these 14mm bolts behind the headrest.
Well now I know for next time
mada51589
05-03-2022 08:54 PM
