Steering wheel backlight/trunk button light
Old Oct 17, 2005 | 02:32 PM
integr89's Avatar
How easy is changing bulbs for the backlight on the steering wheel, hazard light, and the trunk button backlight? I'm under warranty, but last time I had my car serviced they didn't get all my problems worked out. Thought I could do some things myself. I checked garage, but no avail... any diagrams/help is much appreciated.
Old Oct 17, 2005 | 02:56 PM
rbf351's Avatar
Registered User
the hazard lights, you will need to remove the vents, which pull out with a little force
the trunk button, is simple, you can either reach under or pull the kick panel down, it's held on by clips only
steering wheel is easy, but i'm pretty sure you need to remove the air bag
Old Oct 17, 2005 | 03:33 PM
integr89's Avatar
what bulbs do they use? Also, is there somewhere in the garage that mentions how to take out the airbag? thanks!
Old Oct 18, 2005 | 12:41 PM
need4spd's Avatar
an Acura has-been
If all those bulbs are out at the same time, I would suspect that it is not a bulb issue, but a wiring issue. Possibly a pin in one of the connectors is not touching.
You may find that this is not something you can repair.
Start with the simplest one, and see if it even has power, if no power, you have anouther issue at hand.
I do not think it is a fuse issue, since it is only a few lights, more would be out at one time.
Old Oct 18, 2005 | 03:37 PM
rbf351's Avatar
Registered User
not possible to be a wire since they all use different ones, also if it was a fuse all of his interior lights would be out
goto www.acuraparts247.com and look up the bulbs you need
Old Oct 18, 2005 | 06:30 PM
KJSmitty's Avatar
WDP Director of R & D
Need4speed is actually correct here. Maybe not in the sense that it is 100% a wiring issue, but the proper diagnostic process would be to remove the most accessible lights and check for power.
It may very well be bad bulbs but better to check the easy ones vs R&Ring them all just to find out they still don't work.
Either way I would be checking power and ensuring all new bulbs functioned prior to finalizing the "re-installation".....
Old Oct 18, 2005 | 07:23 PM
speedracerIII's Avatar
airbag is removed via 2 Torx T30 in thru either side off the steering wheel...Not sure the bulbs are serviceable separate..Perhaps you need a new switch...Check wiring first and check fuses
Old Oct 18, 2005 | 07:48 PM
rbf351's Avatar
Registered User
all of the bulbs in the switches are replaceable except for the mirror switch
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Charlespsu
Sep 2, 2015 09:54 AM
