Squeaky Brakes
Old Mar 30, 2004 | 11:19 PM
jessecube's Avatar
Squeaky Brakes
Does anyone else have squeaky brakes with thier 6sp TL. The problem started for me around 1,000 miles and seems to keep getting worse (currently have 5,000 miles on it). Usually does it at low speeds under very light break pressure, mostly when driving around parking lots.
I've had other car brakes do this from time to time, however its quite religeous with my TL. Regardless, it still stops on a dime!
Old Mar 30, 2004 | 11:24 PM
caball88's Avatar
have same problem but i've only got 1200 miles on the car so far. it was posted by other members as well but its suppose to go away after a while. if you have 5K and it still sqeaks i would take it to the dealer.
Old Mar 30, 2004 | 11:32 PM
Aegir's Avatar
Powered by Guinness
Yes. There have been a couple recent threads on this. I thought it had cleared up after 1800 miles, but yesterday mine was squealing again. Other than that, I'm very happy with the brakes. I'm debating whether or not to take it in or live with it a while longer. I haven't heard of any dealer solutions yet...
Old Mar 30, 2004 | 11:44 PM
ComptechType-S's Avatar
Time to POWER UP!!
Talking
Your brakes need to be "seasoned". What you need to do is get you car up to 70 mph and then stand on the brakes as hard as your can. Do this about 4-5 times and then repeat at 80 mph 4-5 times. This burns off the "glaze" that has accumulated on your rotors. You will also need to keep you rotors from gettin wet until they can cool down on their own.
Old Mar 31, 2004 | 12:07 AM
Aegir's Avatar
Powered by Guinness
--Your brakes need to be "seasoned".
I'll give it a shot. If nothing else, it sounds like a lot of fun!
Old Mar 31, 2004 | 06:49 AM
GoBig's Avatar
I have the same problem and I have 7,000+ miles. It can be annoying, but I'm getting used to them.
Old Mar 31, 2004 | 09:00 AM
caball88's Avatar
shoot its raining today can't "season" my brakes.
Old Mar 31, 2004 | 10:36 AM
Tvalenzuel's Avatar
8th Gear
The "squeaky brakes" that you're impelling are due to the brake rust on the brembo brakes of the 6MT. I just had mine for only 2 weeks and heard that brakes squeaking on low speeds such as in a parking lot as one of you describe. Went to the dealer and and the brake pads cleaned. Dealer told me that once in a while it will squeak but it's normal. Only problem is ... it's embarrasing especially when people look at your new TL and hear that noise. Hopefully the problem will fade away.
Old Mar 31, 2004 | 11:10 AM
apwalsh's Avatar
The sqeaking of the brakes are normal and will never go completely away unless you change to another brake pad. The Seasoning (Bedding) of the brakes doesn't actually do anything for the sqeaks, but it is supposed to increase the performance of your brakes by removing any impurities or bumps in the pads. If you want to sqeaks to go away forever, you'd have to use a softer brake pad which will create even more dust. These brakes and pads were not made for mild braking, they are geared towards perfomance. Brake more aggressively and you won't hear any sqeaks.
The G35's have the same problems with their Brembo/pad combo.
Old Mar 31, 2004 | 11:27 AM
caball88's Avatar
no more brake dust!!! i hate brake dust, the front rims look are gray while the rear rims are silver. it sucks i hate having to clean it all the time. i will deal with the squeaks.
Old Apr 2, 2004 | 10:54 AM
Time to POWER UP!!
I did the "seasoning" and mine dont squeek anymore.. Anybody else try it?? I am also looking into the "green and red stuff" replacement pads.
Old Apr 2, 2004 | 10:57 AM
caball88's Avatar
i didn't do it but after the rain i have not heard it anymore. lets hope it stays that way.
Old Apr 2, 2004 | 11:30 AM
GTFISH's Avatar
Good suggestion on the "seasoning". I have always called it bedding in of the brakes. Basically you try to match the rotor and the pad together so there is uniform contact.
Also try flusing out the rotors and calipers with water when you wash the car, seems to help with my other cars.
Old Apr 2, 2004 | 12:52 PM
caball88's Avatar
do not flush the brakes when they are hot, its could be very bad. metal expands and contracts when hot and cold. doing this could possibly damage the breaks.
Old Apr 2, 2004 | 03:01 PM
GTFISH's Avatar
Duh! I guess I shouldn't assume some people are smart enough to realize that.
Old Apr 3, 2004 | 09:13 AM
jessgabby's Avatar
I had 200 miles when I complained to Acura Mission Viejo about the brake squeal. Took them 1 week to order new pads and got it replaced at 1100 miles. Drove it for 1 day with no squeal. Next day, it squealed again. Called them and complained and they told me that they will contact Acura to get more info.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
