A-Spec Body Kit Self Installation
Old Feb 5, 2005 | 12:11 PM
stklee's Avatar
Has anyone install their own A-Spec body kit? How difficult is it and can an average Joe do it? Thanks!
Old Feb 5, 2005 | 04:54 PM
Ron A's Avatar
Administrator
A look in the 3G Garage would have shown this thread,with the heading: Self installed A-Spec suspension
Old Feb 5, 2005 | 05:06 PM
lbbrando's Avatar
Acura Dealer Technician
I can email the actual intructions from acura if you want.
Old Feb 7, 2005 | 11:06 AM
stklee's Avatar
Thanks for the reply...but I am actually looking at the body kit self install not the suspension. Do you have any idea? Thanks, Sam
Old Feb 7, 2005 | 12:00 PM
rbf351's Avatar
Registered User
i have those instructions for the entire body kit if you want, PM me for them
Old Feb 7, 2005 | 12:07 PM
cygnus2948's Avatar
As I have stated in past posts the kit is relatively easy to install. I have installed two one on my 04 and one on the 05 I traded my 04 for... I have little experience with bodywork or mechanical and I found it to be VERY easy install.
The first kit took about 10 hours because I was VERY carefull! Read the instructions multiple time, etc... The second install took about 5 1/2 hours... There is some drilling required, adhesive tape and mounting to stock locations. If I recall correctly I drilled 10 holes. Most of the holes are in place that if I took the kit off would never be seen. The only exception is on the back bumper you drill four holes that are plainly obvious without the body kit.
As a side note I did the work in my garage only pulling the car up on portable ($15) ramps for the front installation... And it was cold causing me to have to heat the adhesive to avoid gaps. It is better done in temparatures above 70degrees, if not be prepared to heat...
Old Feb 7, 2005 | 12:35 PM
DopeTL04's Avatar
How hard is the install just for the side under body kit. From what I have heard the sides are the easiest compared to the back and front. Is there any drilling needed for the sides?
Old Feb 7, 2005 | 02:37 PM
cygnus2948's Avatar
No drilling required for the sides. Just alot of snap in clips and screws in preexisting locations in the wheel well... The will take you 45 minutes to an hour...
fuct
May 14, 2017 09:43 PM
Zonian22
Nov 14, 2015 01:20 PM
Sep 4, 2015 08:03 AM
nuldabz
Sep 3, 2015 05:49 PM
Aug 30, 2015 02:39 PM
