So our HID only has one bulb. How does it switch Hi/Lo beams?
pretty sure its a blocking mechanism. maybe its called a reflector plate? if you look closely at the beam pattern you can see a direct cutoff in the beam pattern. Kinda looks like this.
XXXXX/
XXXX /
____/
Basically a plate moves over and blocks some of the light so you dont blind oncoming traffic. the plate causes the backwards L shaped cutoff point. If you put your high beams on, you can actually hear the popping noise as the plate moves...i'm guessing it probably flips up and allows the full beam to project out.
XXXXX/
XXXX /
____/
XXXXX/
XXXX /
____/
XXXXX/
XXXX /
____/
Originally Posted by gainful
# months ago, some ppl talked about flickering the HID may impair its lifetime.
So now we know it is safe to do so?
about the beam pattern. I noticed on highway I can see farther on passenger side even though both lights are aimed at same height. Is this normal or am I not aiming it right?
it has a seperate highbeam bulb
In the garage section, under acura tech news is a section that lists all the really nice high tech stuff the TL has built in.
it describes the shuttle for the high low beams, and all sorts of things like the special hardened steel used on the doors to prevent dings, the exhaust manifolds cast into the head (ever wonder why the car warms up so fast?), and all sorts of other stuff.....good reading...
Brett
Brett
Registered Member
Depends on if your HID's are already on or not. If they are on, flickering would probably not harm the HID's because only the plate is moving. Maybe it would shorten the life of the solenoid moving the plate?...dunno But, if your're driving around during the day and your beams are off, flickering the HID's probably would impair its lifetime since you have to cut the beams on and off for them to flicker. I think the most stress on electrical components is generated from constant switching of on/off.
Actually, this is not good for any lamp type, by it HID, flourescent, or incandescent. With filament-type (resistance) lamps, you'll have an increase in tunsten boil-off. This will significantly shorten the life of the filament.
Registered Member
Just one HID lamp per side.
The DVD-A Script Guy
Originally Posted by SouthernBoy
No, the TL HID headlamp system utilizes a single HID lamp for each side and a solenoid control shroud that raises or lowers, depending upon whether you are using your high beams of you low beams.
Brett
Brett
Registered Member
Brett
Brett
First you click on the >>> 3G TL Garage - Newbies & Return Members Please Read <<< sticky. Then you scroll down to VIII. Acura TL Technical info from Acuranews and click on that, and you have found it.
registered !!
Try this, on a quiet area (maybe in ur garage), sit inside the car, with the door open, and flick the high beam on and off, you'll be able to hear something shifting or moving in the bulb area.
AmplifiedDetails
09-24-2015 02:55 PM
